I have an Akai 4000DB tape recorder which really needs the dust removed from inside the wood case. I want to know the trick to removing the tape recorder plate which has a spring connected under the plate to the case.
pishta68
  • 593 Answers
SOURCE: How to disassemble case.
Pry the metal spring clip in the base of the hotshow toward the rear of the camera with a pocketknife, itll pop out and there will be 4 small screws under there, Ill put a buck on that bet. The hotshoe needs some good anchors to support some beefy flash units so it has screws to hold it down, metal hotshoe to metal chassis.
Posted on Feb 07, 2008
SOURCE: Stuck Tape Removal
with only te power connected, press the eject button for approx 10 seconds. The drive will reboot and hopefully eject the tape.
Posted on Aug 01, 2008
SOURCE: need to replace the master power window switch.
No, I just took out the wood panel off of mine and open the black box once you get it out. You will be able to get access to all buttons and take them out and replace them if you need to.
Posted on May 12, 2009
  • 3 Answers
SOURCE: tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
Posted on Jun 04, 2009
  • 34 Answers
SOURCE: My freezer door will not stay shut. Dometic Model RM2453.
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Posted on Jan 03, 2010
Akai GX-77 isn't erasing the old music on a new recording. Can hear the old music on the new recording. Please help. Thanks
Akai or Sony- just problem with erasing head. Usually erasing head looks like black and smoller near reading head. Can be problem deeper inside 'Tape Decks'- wire, no signal to the head and etc.
Oct 13, 2016 | Audio Players & Recorders
? the tape is jammed in the recorder
You will have to remove the outer case to get access inside, then carefully remove the tape from the mechanism and wind the slack tape back inside the cassette.
Jun 20, 2016 | Panasonic Dmr-Ez48v Dvd Recorder
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Dust filter has indicated extreme level of dust for several days making the fan stay on high. any way around having it professionally repaired?
- Remove the top two screws from the control panel.
- Remove the control panel. Be careful not to pull to hard as there is a ribbon cable taped into place.
- If the ribbon cable is taped, remove the tape and set down the panel as to not put weight on the ribbon cable.
- On the top left side of the unit (behind the dust sensor), there is a small box that is held in by a screw and plastic clips. Remove the screw and put tension on the clips so you can remove the box.
- there should be two holes in the box (one on each side), use a cotton swab and alcohol to clean outside and inside the box. I reached inside with the wet swab as far as it would reach.
- While you are in there, take some time to remove as much dust off of the front panel and anywhere else it may be.
That did the trick for me.
Dec 24, 2010 | Kenmore EnviroSense 85501 Air Purifier
Going back and forth from recording to dubbing tapes
If there is a switch (either a mechanical switch or a relay) that changes the recording mode (something like normal/dub or record/dub), it might have oxydized contacts and this may be the cause of the problem. Cleaning the contacts inside the switch/relay or replacing the switch/relay will probably solve this.
You may want to check the switch prior to removing it. You can do it with a continuity tester (possibly with the kind that gives a sound signal when the continuity is good).
Otherwise, if the switch can be disassembled in a simple way, see if the contacts inside the switch are brownish/oxydized, if so, you need to clean them, but you also need to clean the clips that connect the contacts. Some fine sandpaper will do the trick, but be careful when you disassemble and reassemble the switch, some parts can easily get damaged.
regards
3rq8 (Triarcuate)
Nov 18, 2008 | Tascam 322 Advanced Dual Well Single...
Vhs stuck - plastic roller part floting inside case.
You could probably do it yourself, but it would be best if you got professional help, you know, just in case if you don't know where the part went.
Oct 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Door panelremoval
Remove the plastic bezel covering a screw on the inside inner door handle, remove the screw, remove the door handle bezel, pull the wood out slightly from the door handle and slide forward, remove the 2 screws behind the wood, life the top part of the casing off.
Now underneath the grab handle there is a screw, remove it, on the top rear of the door casing there is one more screw sometimes covered with duct tape, remove it.
Gently pull the bottom of the casing away from the door and slide ip upward.
Disconnect the multiplug connectors and that is it.
You will have to temove a white plastic SQUARE slide clip from the casing and place it back on the door for installation.
JPTCAT
Aug 01, 2008 | 1995 Jaguar XJ6
Record won't turn
Often the platter just comes straight up and off its spindle. The belt is long and runs to a small pulley off to the side. IF it is a direct drive (not likely) then there is no belt, obviously.
Mar 04, 2008 | Philco (R) Suitcase CD Shelf System
Won't read DVDs
Hi, Ive just repaired several liteon's ( incidently they are identical inside to some philips models ). In most cases the non writing or non reading problem is caused by dust on the laser glass. You have to open the unit then remove the dvd drive then remove its covers and just give a wipe of the laser with a clean non fluffy cloth. If theres lots of dust in other parts of the drive then this will need to be removed also as it could easily get onto the laser when in use. Even almost new liteons can suffer the problem , it only needs a little bit of dust to top the laser shining onto the dvd , instead the dust just reflects the light back. Hope this helps.
Oct 27, 2007 | Lite On LVW-5115GHC+ DVD Recorder
61 people viewed this question
 Grubhead
Grubhead
