Hp pavillion dv8000 won't boot up
The laptop was restarting after installing some windows updates, then decided to no longer boot. It will POST and then come to a black screen with a flashing cursor and does nothing else after that. Test the HD and RAM and they are both fine, anyone know of a solution?
  • 1 more comment
  • sdrothwell Nov 11, 2008
    I am having the exact same problem with my dv8000t
    worked 11/09/2008, turned it on 11/10/2008 am and nothing. Just the curser in the upper left corner of the monitor.
  • Anonymous Dec 16, 2008
    my dv8000 wont start at all, I removed the battery plugged in the AC power - it started then Window unexplainably went into hibernation mode, then it blacked screened and wont start with or with out battery. I followed HP troubleshooting and reseated RAM -still nothing
    When I hold down the on button the charge indicator on front of lap top flashes thats it dead in the water
  • Johnny Massengill
    Johnny Massengill May 11, 2010
    What operating system are you running on this computer? If it is Windows xp, 2000 or vista, try pressing the F8 key right after the POST (and I do mean RIGHT after the post), this should bring up a menu and one of the menu items will be "Last know good configuration" choose that and see if the computer will boot. If this doesn't work I would take the computer to an HP authorized repair station.
Hp fences wont close with double click
Uninstall fences, reinstall. I would go for the older version, the updated version 2.0.1, is a Commercial Trial. Found here:
Dec 11, 2012 | HP Pavillion Dv7 1240us 17 0 Inch Laptop...
I have HP Compaq 6710b, Some days it got restarted and then never came through in OS (XP). After POST the screen got blank and nothing happened. I reinstalled my OS by using Repairing Options. Now when...
The hard disk got damaged and it's dying - the boot take longer because the boot sector was damaged and it had to be relocated.
Create a reinstall disk with the utility HP has installed in the laptop, buy a new hard disk and install it and then reinstall Windows with the disk you created.
Sep 05, 2011 | HP Compaq 6710b Notebook
I have a problem my laptop hp pavillion dv6000 cant boot windows vista always restart ..
Did you try safe mode and see what happens? Normally during boot up time, press f8 and it will give you the option to go into safe mode. That could be the case of a corrupted files somewhere but you cannot tell until you start troubleshooting. If that does not help then post your problem here and someone else or maybe myself will try to help you. Hope this helps, good luck...
Aug 16, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion DV8000 Laptop won't boot.
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
Click here for more information
Nov 27, 2009 | HP Computers & Internet
HP Pavillion DV8000 Factory Restore
HP.Support.drivers put your model number in the search box, choose drivers - software. All the files that are compatible with your computer are there for the downloading and all is free.
Sep 09, 2009 | HP Pavilion dv8000z Notebook
I m using ur model HP PAVILLION DV2000
Sounds like you have a driver issue.
Start up in safe mode (press the F8 button about once per second after you power on), and select safe mode with networking.
When you get into windows, use windows update to download all updates for both software and hardware (update will till you that there are optional updates available, download these as well),
Hopefully when all that has completed you should be able to run your computer as normal. If not there may be a problem with the memory installed on the laptop.
Jul 16, 2009 | HP Pavilion dv2000t Notebook
HP dv8000 w/vista keeps restarting and the monitor is blackl
Try to boot into vista's safe mode, this can usually be done by pressing F8 after POST, but before you see the vista loading screen.
Once in safe mode go to:
Start > Control Panel > System
on the left you will see " Advanced System Settings " Click that
a new window will pop up with your system properties, click the " settings " button near " startup and recovery "
Make sure the little check-mark near " restart automaticly " is NOT check, then apply, and OK out of all screeens and reboot the system. If the problem persist, you may need to insert the Vista disk into your system, and do a recovery, or restore.
May 30, 2009 | HP Pavilion A730N (PJ510AA) PC Desktop
Having problem with start up on Hp Pavillion dv8000
Try choosing "Last known configuration that worked" if this does not fix you problem, then reboot once more, and while it is booting up tap the F8 key and select safe start.
Ps. you may just need to do a fresh re-install
Jan 18, 2009 | HP Computers & Internet
HP Pavillion won't boot
has windows been registered.
if so your gonna have to reinstall windows.
make sure os disk is in cd tray ..boot up...choose install (not repair) sys check says os already installed continue install or this point choose repair..this way any files or downloaded programs wont be lost.
Jan 10, 2009 | HP Pavilion dv9000z Notebook
HP-520 shutdowns while restaring after vista updates installed
This is something you no longer have to worry about. Vista is no longer being supported so Microsoft will no longer be releasing new updates.
Windows Vista Reaches End of Life Capital Support
May 06, 2017 | E-Machines M5310 PC Notebook
Computers & Internet Logo
1,704 people viewed this question
David Payne
David Payne
