Question about Vizio GV46L 46 in. LCD Television
DTV Tuner Inoperative Until it Warm UP
My 2 year old Vizio 46 LCD won't give me a picture on DTV until it runs in analog or some other like DVD for about 30 minutes. All other inputs are fine from cold start up.
There is an audible click/pop noise then it tunes in DTV.
It had been making ticking, popping, and clicking for quite some time as if it were some thermal expansion.
  • 3 more comments
  • jcsteak Dec 07, 2008
    I have the same prob. I tried watching DTV tonight. The screen is blank. Every other function works including HDMI, TV, AV1, RGB etc. I tried turning it off and on again. DTV goes blank and the remote will not work. It use to say searching for signal in DTV but says nothing now. If anyone has an answer please email me.
  • Richard Tirado Jan 03, 2009
    I have the same problem minus the popping and crackling.
  • nlse Jan 17, 2009
    We have the same problem. When DTV is selected the screen goes blank and the remote no longer works. The TV is about 2 years old and this has been going on for about three weeks.
  • nowonder Feb 01, 2009
    26 month old, same deal, Iv'e thought about opening the thing up and warming the parts with a hair dryer to try and isolate it. I called vizio, if you do this ask for techs phone # its not 800 so hung up when auto-pilot put me on hold. good luck
  • juicebox3170 Feb 25, 2009
    same problem with the dtv and vizio wont help me one month after the one yr mark to
    New Friend:
  • 56 Answers
The DTV board is bad. Replace the board will fix it.
Posted on Feb 18, 2009
The DTV input in my GV46L stays black. Why?
You don't say what you are trying to input but take note that your model does not have a digital tuner on the DTV input. If you use a digital OTA antenna, the signal must first go through a digital converter or tuner before it goes into the DTV input. The DTV/ANT input is only cable ready. There is no digital tuner in the TV to activate the DTV menu.
Nov 02, 2012 | Vizio GV46L 46 in. LCD Television
GV42L vizio tuner
Your vizio has an internal digital tuner. When you are on air, make sure that it is set up for digital. It might say DTV. Some sets have an analog only and digital only program option in the user menu, or as a seperate input. When in doubt, check your user manual.
May 02, 2012 | Vizio GV42L 42 in. LCD Television
My Vizio VW 26L loses all the digital channels when it is turned off. It works fine after a channel scan, but when it is off then back on there are only analog channel available. Bad tuner?
Tries different antena like a roof antena,or digital antena get better amplication input for receptions,still have signal not ur DTV tuner.
Sep 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
DTV signal will not come up on start up but after warm up
Was just the DTV card replaced only or the mainboard? Replacing the entire mainboard should do the trick.
May 22, 2009 | Vizio L32 32 in. LCD HDTV
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Jan 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
DVD recorder with NTSC tuner
Hey Whormd,
If neither your DVD recorder nor your TV has a digital (ATSC) tuner, they will not be able to directly receive over-the-air broadcasts after the DTV conversion is completed without the assistance of a set-top converter box. Please keep in mind that the official analog broadcasting cut-off date does vary by country. In the U.S. this date is February 17th, 2009, and that Canadian TV stations have until August 31st 2011 to make the transition.
Please also note that you will need one converter box for each device with an analog tuner, in order to watch one program while recording another. One converter box would need to be connected to the DVR, while the second converter box would need to be connected to the TV itself.
For more information, I would strongly suggest checking out the FAQ sections of the official DTV websites established by the Federal Communications Commission (FCC) and the Canadian Radio/Television Telecommunications Commission (CRTC): (FCC) (CRTC)
Hope this helps you out.
Go Ahead. Use Us.
Jun 10, 2008 | Pioneer DVR225 DVD Recorder
Vizio GV46L 46 in. LCD Television Logo
750 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
