Question about Dell 0Y3740 Keyboard
Dell Calculator Hotkey
I used to be able to bring up multiple calculator windows each time I pushed calculator hotkey. Now I push it once and get one calc. window. Push it again and nothing happens. Sometimes I need 3 or more calc windows at a time-how can I configure button work again to bring up another calc(s). when I need it?
  • 88 Answers
Verify if multiple calc works if you launch it from windows, without using the hot-key. if that does not work, its a windows issue - might need a full repair / install. If windows is able to launch it - you can fix the issue by reinstalling any drivers for your kbd.
Posted on Jan 11, 2009
When I enter a number using the + button, it often adds it multiple times
You may be pushing it down to hard or holding it down for too long. Try pushing and releasing it very quickly.
Good luck,
Feb 10, 2016 | Canon Mp25dv Desktop Calculator 8077a006ab
Use Winsize2 to remember any Windows Size using its HotKey
I always had trouble with IE8 not holding its full size window and also the command prompt for my batch files on my 1280x1024 TFT screen I tried many Reg Tweaks but none seemed to work after a restart, then I found Winsize2 on this download link
When you use the standard hotkey "CTRL+ALT+Y" on the active window it will save the windows size in its own ini file so that if the window is closed it will always reopen with the saved size that it was when you used the hotkey
Winsize2.ini file stored in the Margrasoft's %appdata% folder will auto-increment value AWNr_x as for each time the hotkey is pressed, you can edit the Special Parameters by right clicking here is an example showing the command prompt resized larger than the default settings. You can also check the use a different ini file for each screen width 1280 or 1024 etc.
NOTE: This will not overwrite the command settings in the Command Prompt properties window if its set to a width of 100 winsize2 will resize and use its ini settings
on May 15, 2010 | Microsoft Internet Explorer 8
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
Jan 25, 2013 | HP Compaq Presario C769US Notebook
My TI-89 calculator turns on, but gets stuck on window editor
If you're willing to have all RAM cleared, try a hard reset.
Press and hold the 2ND, Left-arrow, and Right-arrow keys.
Press and release the ON key.
Feb 20, 2010 | Texas Instruments TI-89 Calculator
Cannot invoke hotkey function to switch computers .Directions say use num loc key plus minus key and release num loc but this doesnt work.
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, a much better hotkey for this switch is to tap scroll-lock twice. This automatically switches, so you don't have to hit multiple buttons.
Feb 18, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
I have an hp ze2000. I hooked it up to an external monitor. When I unhooked it and restarted it my laptop screen now stays blank. Who knows the answer to this?
I think you have to reset through setup F12 or is it F8 restart and push one or the other, then locate menu for screen click to enable.
Haven't come across this before. Best I can suggest?
Nov 16, 2009 | HP Pavilion ze2000 Notebook
There is a way to do it. I believe you go into "complex" or "math" buttons. These buttons are yellow on the calculator. Therefore, to access them you must hit "2nd" then the button.
Better yet, you can also get around this dilemma another way. You can enter "the cubed root of x" by raising x to 1/3.
For example the cubed root of x = x^(1/3). It is best to place parentheses around 1/3 so the calculator knows exactly what you mean.
Another example, the "cubed root of (x + 1)" can be entered by:
(x+1)^(1/3) Note the parenteses around both (x+1) and (1/3). This applies if the radical cover both "x" and "1".
Hope this helps.
Oct 03, 2007 | Texas Instruments TI-86 Calculator
Dell 0Y3740 Keyboard Logo
590 people viewed this question
Alun Cox
