Question about Panasonic TX-32PK1 TV
Panasonic Hi I have a panasonic tx32pk2c, euro chassis 4, i can no longer use AV2 or AV3 with any device i have tried to connect, whreras it worked fine before with all of them. AV1 is working fine as is the tuner. i know the tv is outputing some kind of signal as my computer detects it when i plug that in but i cannot get any picture or sound. any help on this would be greatly appreciated
    Scholar:
  • 68 Answers
I do not have the details of this set but if you go to Google and type in the model number you can download the PDF file from sites, also there is a radio ameteur which specialises in Panasonic. From the faults reported it sounds like a bad soldered joint on a component which may be close to the AV inputs.
Posted on Oct 15, 2006
SOURCE:
AV1 red, white and yellow cable ports not working. I use digital satellite service for my television through a box from my provider which only uses the AV1 port? I checked all the wires which were working...
Your post is a little confused (or I am!), why would a digital box only provide a low resolution output which is what the composite standard is - yellow video composite red/white=stereo audio.
You also say that you checked the wires, so you've seen the picture and heard the audio on AV2? So why not use AV2? There is no reason to use AV1 other than you may be using the other inputs for other equipment.
Check that the output from the cable box really is composite and not component, and if it really is composite check the AV colour system in the TV menu is set to Auto (or NTSC if you are in USA, PAL in Europe)
I think you (or I) may have misunderstood how to connect it, can you have a look at your cable box and see what the output sockets are labelled and report back/clarify also detail what your cable equipment is please?
thanks
May 17, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Cant find AV2 on a panasonic
Check the input connections. The input connection to AV-2.
Jul 03, 2012 | Panasonic Televison & Video
A power surge caused my tv to power off and now I cannot find the "Standard tv channel." I have a blank screen with "AV2 video" in the upper left-hand corner, but no picture. I have...
The surge may have scramble the mother board, try unplugging it for about an hour to let it reset itself, if that does not work, then you may need to replace the main board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 13, 2011 | Hyundai Televison & Video
I have a 42 inch panasonic viera th-p42g10a. i have dvd connected to av1, foxtel to av2, av3 is vacant. I have lost volume to both dvd and foxtel connections, yet i still have volume when watching normal...
This is a problem with your components. You can have the components replaced with a new set which may be expensive, or live to learn using av3 only with a switch system.
Mar 03, 2011 | Panasonic VIERA TH-42PX80E 42 in. Plasma...
Trying to hook up a PS3 to a regular older TV (Zeneth). What do we need to make this work
hello just the black lead that has 3 coloured jack plugs on the end and scart block. on the tv at the back there might be 3 scart sockets av1 av2 av3 or e1 i'd connect it to av3 good luck
regards
shaun
Jul 17, 2010 | Sony Playstation 3 (PS3) Console
I have a Panasonic DVD Recorder DMR-ES30VEB could you please tell me if this will still be able to record if I buy a new Panasonic digital TV??
Yes, connect to AV2 and you can select the output for AV2 from the menu.
Most tv's send a selectable signal out through av2 but if you match to your Panasonic, you may find it will automatically set up with the dvd recorder(like Sony Smartlink)
You simply go into the menu, select the av2 output set up and pick what you want to record. I.E. dvt, av1 etc.
Sep 04, 2009 | Panasonic DMR-ES30 DVD Recorder/VCR
Setting up the Panasonic DMR-E55 DVD Recorder
If the freeview box has a SCART output, connect that to either AV1 or AV2 on the Panasonic. To record, select either AV1 or AV2 as the input. Use the other AV to connect to the TV to playback.
Jan 28, 2009 | Panasonic DMR-E55 DVD Recorder
Hook up for dell inspiron 6000 to panasonic th-50px80u
the TV supports resolutions as follows:-
VGA (640 × 480 pixels), WVGA (852 × 480 pixels),
XGA (1,024 × 768 pixels), WXGA (1,366 × 768 pixels)
You need to set the PC desktop res to one of these resolutions and then simply connect the VGA o/p on the laptop to the PC input on the TV. You can also connect the audio out of the PC to the TV if you wish by connecting the audio into AV2 audio input on the TV
The other option would be to use the S video o/p on the PC and connect into AV3 input (audio inc) but I suspect the picture quality will be better via the VGA
Please post back if you have other questions or problems.
Jul 15, 2008 | Panasonic Computers & Internet
Problems using video to record from tv
The tv has 3 scarts try connecting to AV3.
If still no luck go to the TV Menu and then 'Setup Menu' find settings and change AV2 OUTPUT TO TV.
Nov 11, 2007 | Panasonic TH37PX60 37 in. Plasma...
Panasonic TX-32PK1 TV Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
