Question about Bosch Refrigerators
If you lay a Bosch fridge on its back to move it. How long do you have to let it stand before you can plug it in.
  • 47 Answers
2 hours. It's a standard for all fridges.
Posted on Nov 06, 2008
Am moving an Admial fridge. Can I lay on side or front? How long after moving and standing up before I can plug in?
best bet is not to lie it down. i think if its upright at least 24 hours it might be ok but i wouldnt count on that.
Apr 19, 2017 | Refrigerators
Moved the fridge and when we plugged it in, it wont come on
has to be left standing not plugged in at least 24 hours . for the oil to run back to the compressor
Jul 25, 2015 | Haier 40D3500M 40 1080p LED-LCD TV - 16:9...
If I lay my smeg fridge freezer down to move it will it break.?
it won't break, but it will get air in the lines,, once you move it,, stand it up for a day ,, then plug it back in,, the air will work its way out after a while, you may hear some gurgling noises,, if they do that a lot,, Juast unplug the unit again and let it sit for another day
Sep 05, 2011 | Refrigerators
Hi there, I have a Samsung RS21DCNS F/F. and have just moved house and connected it all back up. The LED display lights up, but the fridge and freezers won't cool and there's no motor or fan...
Was the fridge laying down? How long? Rule is if a fridge is laying down for an hour leave standing for a minium of an hour WITHOUT PLUGGED IN. ^hours laying equals 6 hrs standing. I tell everyone give it 24hrs of standing to eliminate problems. If you plugged it in without enough time for the oil in the compressor to return back to the compressor you may have fried your compressor. Now if you did leave it long enough and the oil in the compressor got back in compressor before plugging in. It could be in your defrost timer or your start relay. Does the fan in freezer come on? Push the switch to make the fridge think door is shut. If fan does not run it sounds like the defrost timer. If fan does run the check the start relay on compressor. Does the compressor turn on? Do you hear a clicking sound coming from copressor? If you hear a clicking noise than its your start relay trying to come on. Replace start relay and overload. The model number you gave me is not valid so get the full model number and check thru Searspartsdirect.com
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung Refrigerators
What is the proper way to move the fridge?propped up or lay it down?
For tranporting you must keep it upright. If you have to tilt or lay down be sure to let stand uprigtht off for 24 hours before turning back on.
May 15, 2011 | Kenmore 53092 / 53094 Side by Side...
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
Moved fridg to new house pluged it in dosen,t get coled at all!!!
If you had to lay the fridge down to move it? Then you have to let it stand upright for at least 24 hours before you can plug it in and use it or it won't cool, as oil will get into the coolant lines and foul the works.
If you didn't have to lay it down, then check for a switch and or harness under the front grill that may have got bumped out of adjustment of knocked the plug off.
I hope this helps you, and good luck.
Sep 16, 2009 | Maytag MBB2256GES Bottom Freezer...
I just moved my dads fridge to my house and after about 7 hours I smelled a burnt plastic smell. I smell it on and off.The fridge is still cooling.When i moved it I layed it down.
When a fridge is layed down the oil in the compressor will flow into the refridgerant lines and will have to be stood upright until the oil can return the the comrpessor. It may be too late for yours but I would try cutting it off for a day before trying it again. This may not be the cause of the smell so keep a nose on that and try to locate exactly where it's coming from.
Aug 21, 2009 | Whirlpool GC5SHEXN Side by Side...
Kenmore top freezer. Bought it from a lady. Only
Was the fridge layed down when moving ? If so , did you let it stand for 24 hrs before plugging it in ? If you layed it down and didn't wait to plug it in , it's no good .
If you did not lay it down , remove the back panel and see if the compressor is running . If the compressor is hot but not running ,possible overload/relay bad . This is the piece that plugs onto the compressor . Also check that the fan that cools the compressor is working .If you remove the inside freezer panel , check to see that the freezer fan is working . Check to see if the coils are getting a light coat of frost on them .
Aug 21, 2009 | Refrigerators
Dishwasher pumps water in and out, but does not wash
Try tilting the machine back 45 degrees for one minute 7 then try one of the programmes. Serousely outr Bosch diswasher was firstly not draining water then not taking in water & another forum suggested this odd manouvre & all is fine now
Nov 06, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Refrigerators Logo
119 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
