The lights on the printer keep on blinking and I have cleaned the cartridges and have reset them. I also had them checked for ink and they are full. The orange light blinks three times and then stops. I have disconnted all the ports and then replugged them in. Still no priinter use.
  • 1,879 Answers
Hi - we got disconnected (accidentally ended the chat session?)
for the light pattern that you have here are the related issues:
paper jams , obstructions , cover error
Canon's recommendation:
Resetting the Printer By resetting the printer'spower, the print buffer is cleared and certain sensors are reset. Ifthere is invalid data in the buffer, or sensors are stuck in aparticular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplugthe printer's power cord for approximately 10 minutes, and then plug itback in. If troubleshooting a communication issue, reconnect the datacable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note:If resetting the printer does not work, please attempt any othersolutions that appeared in your search results.If this is a hardwareerror on the printer, the printer may need to be repaired.
Issue: Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Solution: The iP1700 may require repair
Unfortunately,the issue you describe seems to indicate that your product may requirerepair service. If you feel your product might require service, aTechnical Support Representative will be happy to answer any questionsyou may have and explain the service options available to you. You cancontact us through the email link or phone numbers listed below.
  • Obtain Support by Email
  • Fortoll-free technical support, please call 1 (800) 828-4040 duringregular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m.EST, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON
The InstantExchange Warranty Program is available:
(1) only for certain printer, facsimile, multifunction, and scanner models;
(2) during the express limited warranty period for such products; and
(3) only in the continental United States, Alaska and Hawaii.
Sowe may better assist you, please make sure that you can access yourCanon product and have the following information available when youcall:
  • Product model name and serial number.
  • Computer's operating system; for example Windows XP.
  • Message displayed when the problem occurred.
  • Steps you've already done to try to solve the problem.
For information regarding the Canon U.S.A., Inc. Limited Warranty, please click here.
Welook forward to helping you rectify the issue you are experiencing andare always available to provide any assistance you may need.
Posted on Nov 06, 2008
    Genius:
  • 1,124 Answers
Clear any paper or carriage path obstructions
With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
Press the On button to turn on the product.
Plug the product directly into a wall outlet Follow these steps to make sure that the product is correctly connected to a suitable power source.
Remove the power cord from any power strips or surge suppressors, and plug it directly into a grounded wall outlet.
Perform a partial reset A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
Unplug the power cord from the unit.
Reconnect the power cord into the unit.
When the lights begin to flash, press and hold the On/Resume buttons.
Try the print job again to see if this step resolved the issue.
If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
If the issue is not resolved , continue to the next step.
Remove and re-install the print cartridges Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center. The print cartridge carriage is the plastic part that holds the print cartridges. When the carriage is at the center of the access area, unplug the printer.
Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
Reinstall the print cartridges.
Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
Have hp 450c orange cartridge light keeps blinking checked all cartridges only black cant get ready light to come on 3x so light keeps blinking.took out black cleaned it but still wont blink ready
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 09, 2011 | HP DesignJet 450c InkJet Printer
Both lights are blinking on printer Epson stylus r230
I suggest you run this tool to fix that problem
It will allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
http://www.ssclg.com/download/sscserve.exe.
Jan 11, 2011 | Epson Office Equipment & Supplies
The orange ink cartridge light keeps blinking. We
the problem is that your cartridges are expired or bad, just replace the two cartridges with a new one
Mar 16, 2010 | HP DeskJet 940c InkJet Printer
Both lights are blinking how to reset r230
please help me my printer epson r230 resete softwar need please help me
Mar 12, 2010 | Epson STYLUS R230 InkJet Photo Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
