Question about GE WBSR3140DW Top Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
My washing machine runs and it smells like plastic is burning. It was spinning fine until today, the cycle finished and the clothes were still soaking wet. Is this something I can fix on my own?
  • 3,741 Answers
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Oct 01, 2009
  • charlymonty Oct 01, 2009
    The new style GE washer has had trouble with bleach, water leaking onto the motor harness plug and burning the wires. If the motor is not damaged, this is how to repair the motor wire harness with kit part# WH49X10007. Sometimes a loose wire connector can also burn the motor wires, this kit will correct that problem as well.
    Remove power!
    Access the front panel clips.
    Remove front panel
    Cut all the wires in the wiring harness to the motor, at the bottom of the steel suspension rod. Strip 7/16" insulation from all seven wires coming from the top of the cabinet. Excess wire will be looped at the cabinet later on in the installation. Unplug remaining harness at motor and discard.
    Install new harness kit
    Find plastic push-in harness retainer on new harness section and insert it fully into existing hole in the right front platform leg. ( see picture below )
    Plug in motor connector until it is seated, make sure that the harness forms a loop below the motor connector to prevent water from running down wires and into motor plug.
    Attach ground wire to hole in platform corner ( see picture above )
    Route wires behind front platform leg. Dress wires upward spiraling between tub and suspension rod, towards capacitor mounted on cabinet flange. ( not all models have a capacitor )
    Match color for color wires in harness and twist them together. Install closed end splice connectors and firmly crimp all seven.
    Using small wire tie, secure all 14 wires together just below connectors.
    Position the wire bundle directly behind the capacitor area with the wire connectors protruding 2 -1/2" above the capacitor area. Secure with large wire tie to either the capacitor or a hole in that part of the front cabinet.
    In addition to wire tie, use black electrical tape to secure wire bundle to the top of capacitor, if provided, to ensure that bundle is secure.
    Install plastic twist clip to secure new harness to suspension rod. Bend both right and left corners of the galvanized drip plate downward about 1/2" to ensure proper water drainage away from motor and motor plug ( if not factory formed - see picture below )
    Reinstall front panel, plug in washer and check for proper operations.
    click this link directly for all pictures and instructions.
    http://www.applianceaid.com/wh49x10007.h...
Spins but wont drain has a slight burning smell
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 05, 2011 | Frigidaire FWS833A Top Load Washer
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
heatman101
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
My top load ge washer wont spin out?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 23, 2010 | GE Washing Machines
My kenmore top load washer works well, however when the spin cycle runs...the water drains but the clothes are still soaked. It sounds like it is spinning (but Im not sure if it actually is) and there is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | Kenmore 24032\24036 Top Load Washer
I accidently washed a large load of laundry without switching from previous small load selection; now washer has burning smell and wont work??
probably broke the motor coupling, it's made of rubber and plastic,when machine is out of balance it breaks, if you turn it on agitate or spin and you can hear the motor running but nothing spinning then it has broken, part cost about 20 bucks Try Repairclinic.com
Jan 31, 2010 | Amana 3.2 cu. ft. Top-Load Washer
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
WHDSR209D Washer
if you have a rubber smell that means that the belt is burning through. Several problems can be the case.
1 bearing of the drum ( check if it turns freely if so the bearing is ok)\
2 the belt is worn and need to be replaced.
3 carbon brushes in motor are worn
4 bearing in motor is gone
open the backside of the machine and check belt.
think that is your problem
Apr 30, 2008 | GE WBSE2090A Top Load Washer
Burn Smell (electrical) from my GE WPSE4200A0WW
We have the same problem, and found out the the electric motor is running very hot. Replacing the motor seam to cure the problem, but the motor is not inexpensive. $200 to $350.
Sep 04, 2007 | GE WBSR3140DW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
928 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
