2004 toshiba laptop, herbernation mode shutdown
My toshiba laptop went into hibernation mode while in an active state and now it won't start up and run normally. It was connected to a wireless network in a motel at the time it did it. Please help
  • 41 Answers
Hi
try to boot the computer from an OS cd and then try to repair the computer it will give you an option while starting up ......
first try to change the boot oder in the bios option ,,,
if you get some problem you can contact me on fixya
Posted on Jul 22, 2009
F buttons description
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
Sponsored Links
Computer Repairs (Melb)
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
Sep 25, 2012 | Toshiba Satellite A100-S8111TD Notebook
Windows 7 won't start up
Log on via save mode and backdate your restore to an earlier date before issues date. All will be fine.
Feb 07, 2012 | Toshiba Satellite Computers & Internet
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
After shutdown of gateway laptop blue power button stays lit.....
Hi this sounds like your computer is in hibernation mode as opposed to shut down mode. Could you check and see as if running Vista many people assume that clicking on the brown power type selection under start that they are shutting down where as this actually only hibernation mode and clicking on the little arrow to the right of this and selecting shutdown is the way to go.
I hope this helps
Apr 07, 2009 | Gateway MX6441 Notebook
My laptop does not fully hibernate!
Unfortunately , hibernation issues are tough to pin down.
See this link
http://support.microsoft.com/kb/907477
Basically says , meh could be anything.
One thing you can do to narrow it down is to go to Start > My Computer > RIGHT click on My Computer > click Manage > expand Event Viewer > Click on Applications and see if you have any Red ! around the time it was supposed to be hibernating.
If you see a message like "application hang" you can try uninstalling and reinstalling that particular app.
An easier way is to use a program called smart shutdown.
http://lifehacker.com/5046541/smart-shutdown-offers-more-ways-to-turn-off-your-pc
This program will kill any unresponsive programs and keep trying to hibernate until successful.
Hope this helps. Good luck!
Mar 04, 2009 | HP Pavilion dv5000t Notebook
Mouse reboot!
many computers only come out of hibernation only when the power button is pressed. you;ll see something that looks like booting up, and the computer will load your memoery from disk of what was in memory when you went into hibernation.
standby is the state that can be woken up by a keyboard or mouse.
http://wiki.answers.com/Q/What_is_the_difference_between_Hibernate_and_Standby_in_Windows
Feb 01, 2009 | Toshiba Satellite M105-S3004 Notebook
Toshiba Qosmio F15 AV201 - permenant hibernation
i have the same problem but the power is completely shutdown
Oct 22, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba laptop A105
Power off the system and wait a few seconds to make sure that hard drive has spun down.
Hold down the "Backspace" key while powering on system.
The following message should appear:
Warning: Can't restore Hibernated State.
Press any key to continue.
After pressing a key on the keyboard, the system will continue with the boot process and the hibernation/standby mode will be by-passed.
a fellow member had posted this
hope this helps
Have a nice day!
tc
Jun 12, 2008 | Toshiba e740 Pocket PC
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
