Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Songy VX2100 I have a VX2100 Sony Handycam. When recording, I think the tape is dragging just a little. This causes distortion in the picture and sound when playing back. In the beginning this only happened at the end of a tape. Now it shows up at the beginning and the end. The middle of the tape does fine. We have been using Maxell DVM60SE Mini DV Cassette Tapes, but have tried a variety of tapes. The bad part is that there is no indication that this is happening while recording, only a nasty surprise later. I have had a hard time figuring out who to call or where to send it if repairs are needed.
    Sergeant:
    Champion:
  • 326 Answers
Hello diddaddy, your Camcorder needs a professional assistance. In order to repair the Camcorder the following parts need a replacement: table assy, reel pn:x39484448 and plate assy,TG1 adjustment pn:X39484357. After replacing adjust the FWD position and the FWD back tension. Autorized Sony Service seems the best solution. If you need more info please advice.
Posted on Mar 24, 2007
I had the same problem when I reused tapes that I had recorded on before, but I don't have this problem when I use brand new tapes. I use Panasonic and Sony tapes and the odd JVC.
Clean the head
I have a DCR-100, which is basically the same camera, and had the same problem after I hadn't used it for about 5 years. After running a cleaning tape through it four times it became much clearer, but sometimes, reviewing my equally old tapes the pixellation/distortion reappeared spasmodically. I ran the tape at FF to the end, and then back again. Seemed to fix it. I think after a long period of disuse the recording heads oxidise and it takes quite a bit to clean them. As to why loosening up the tape works - no idea!
Aug 16, 2014 | Sony Handycam DCR-PC9E Mini DV Digital...
My sony dcr-vx2100 has a problem. while recording the camera will display cassette cleaning yellow icon. this messes up recording process. what should I do?
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 24, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
There is a problem of ?timecode? with ?Sony DCR-VX2100 MiniDV?: Yesterday it functioned correctly, and this morning, when I support on REC, the ?timecode? begins again to zero, and when I stop filming it N...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Jan 23, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
A yellow symbol is flashing on screen, its a small box with what looks like a yellow rain drop inside if that makes any sense. I think this is affecting the timecode, the camera says it is recording then...
The symbol indicates moisture in the tape mechanism. This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Dec 14, 2010 | Sony Handycam DCR-VX2100 Mini DV Digital...
Microphone for the vx2100
Can you find a replacement clip that secure the camera (VX2100) onto the tripot stand.
I also need a good powerful external recording mic for the same camera.
I will purchase tapes also if they are available.
My email slimjim133@hotmail.com
Thanks
Jul 13, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Recording onto a mini dv tape from Mac computer Via firewire
I have successfully recorded to a mini Dv tape from my computer however I connected my PC to the VX2100 using the RCA inputs. I have an adapter that I purchased from best buy that provides the RCA input/output. If your able to connect that make sure to...
1. Turn you VX2100 to Play/Edit mode (not camera mode)
2. Insure the program on your mac has an external output otherwise you won't be able to record.
3. See if your video editing software (if your using one) has an option for record to tape or to camera. I use Vegas Studio and it has an option for that.
Hope this helps. Good Luck!
Jun 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Heavy pixalated playback .. VX2100
Try to clean your heads with a video heads cleaning cassettefor ten seconds and try to read your tape.
If it doen't help, your footage is corrupt.
Dec 16, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Normally these small squares in picture shows error in Tracking and can be set by tape Path adjustments. In some cases, Cassette Mechanism needs to be replaced. Need further info, please let me know.
Sep 03, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Audio
it is the tape running path makes the problem and normally happens in a long run. realign the tape path by carrying to a sony service centre...
Jan 14, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
78 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
