No dvd drive
Pc not recognizing dvd drive
Couple of things to check:
1. Make sure the IDE cable is connected correctly and facing the right way both on the motherboard and on the back of the Drive. Remember on the drive it might not have a guide, but the rule is the stripe faces the power supply connection. On the mother board it normally has a guide that the IDE cable has to fit into.
2. Make sure the jumper settings are set correctly based on the location on the IDE cable the end of the cable requires it to be master most of the time if single drive. If it is running with another drive it has to be set as master or slave if it is on the same cable. Normally best is to set it as cable select. Main thing is it must match the arrangement of your drives.
3. Make sure the ends of the cable on the dvd and the mother board are pushed in all the way, and same for the power.
Hope this helps.
Posted on Nov 07, 2008
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
Dvd-rom sd-616E driver no longer recognized by
Reboot the computer and go into the BIOS, see if its recognized in there, if its not recognized then you'll need to turn the computer off and unseat and reseat the cable and the power connector to the dvd drive. Then turn on the computer again and go into the BIOS, if the dvd drive is still not recognzied then you'll need to replace the drive.
If the dvd drive is recognized in the BIOS and not in windows then you'll need to go into the system restore in windows and choose a date the last time the computer was working, it will restore your computer back to this date and reboot. At that point it should recognize your dvd drive. If it doesn't then your OS is corrupt and you'll need to wipe out the drive and restore your computer back to factory defaults.
Feb 04, 2010 | Gateway 5200XL PC Desktop
The DVD drive will no longer recognize a DVD. It
if u are very sure that the drive is DVD drive then u have download the firmware update for the drive. If its doesnt work definitely the lens maybe weak. So u have to change the drive
Nov 17, 2009 | Acer Aspire 3000 Notebook
HP Pavillion a712n Desktop PC-CD writable drive space all used up; and it wont recognize blank CD
have not fixed it. Can you fix the title ? I sokld the pontiac. This is about an HP PC. thanks
May 28, 2009 | 1989 Pontiac Grand Prix
I cannot get my DVD Rom drive to recognize any DVD
You need to install the DVD decoder that came with the drive such as PowerDVD or WinDVD. If you dont have the disks or setup files for those, you can download a free Windows DVD player program such as VLC Media Player that will work. http://www.videolan.org/vlc/
May 18, 2009 | HP Computers & Internet
Liteon dvd drive not recognizing dvd format disks only cds
Try applying the most current firmware update for your DVD drive: http://www.liteonit.com/global/index.php?Itemid=154&option=com_wrapper hyperlink.gif
Jan 06, 2009 | Lite On Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
