Procom MN300HPA ventless heater conversion
Want to convert from natural gas to propane. Needed parts? Procom will not be able to supply according to them.
  • circut Nov 07, 2008
    Ok, I got the ratings for the gas which are / Pressure regulator setting at 6" W.C. / Inlet gas pressure(inches of water) Maximum 10.5" and a Minimum of 7". This comes from the manual on the natural gas. I do not have a manual for the Propane model to get the specs. And therefore, do not have any specs. for this to operate. This is a selectable model from 7,000/18,000/30,000. It consists of 5 infrared plats as they are called. Which to me are ceramic plates.
    I did take out the injectors (orifices-5) and they were stamped 17. These may need to be changed as well. This is ventless and is very touchy on tolerances. As I have been told. So, my thinking is what lp regulator will I need? Do I need to change down size on the orifices? Help!!!!!!!!
    Procom has been contacted and will not give out any info as to what needs to be done to convert to propane. They state that it is illegal to convert these do to it being a ventless heater. But did provide the statement that it will not work with the stock regulator that came with the natural gas version. Those specs were provided in the above thread for the natural gas. Injectors was also mention as needed to be changed (orifices). They have this heater in a propane version but will not give out any information. No less. They do not want me to change or alter this in anyway. But!!!!!!! Any further suggestion??????????
  • 108 Answers
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Posted on Nov 07, 2008
  • Ray Nov 07, 2008
    11" WC is OK. All regulators should be rated as to capacity as to BTU/Hr You need to demand this info.
    Ray
  • Ray Nov 08, 2008
    Natural gas and propane are very different gases. For your heater you will probably need 28" WC regulator outlet pressure for the heater to operate correctly. All pressure regulators are adjustable. Remove the cap at the top of the regulator and you will find an adjustment screw. Turn it clockwise to increase outlet pressure. I strongly suggest installing a "tee" fitting on the regulator output, and installing a pressure gauge that reads WC. Failing that, get a 1 psi regulator and turn the screw counterclockwise to reduce the outlet pressure somewhat. Installing a pressure gauge is important for proper combustion.
I have a Procom MN300HPA ventless heater and the pilot will not light with well gas. Is there some type of converison necessary to get this unit to work or do I need to get a new unit. ProCom will not...
yea,they don't want any liability.a pressure conversion for most gas valves is simply changing a spring.you can get an adjustable regulator if yours doesn't come apart.sounds like you have enough pressure I'd take the piolit apart and open up the orfice hole its real tiny.also burner hole could be widened a bit.I'd never do this for a customer because of liabality,but would be safe as long safties are in place
Dec 24, 2010 | Heating & Cooling
Hello, How to convert a ProCom VentFree Stove QL300TYLA from Propane to natural gas..
yo have to get a kit the orifices are way different because nat gas runs at one half a pound and propane runa at 10 pounds
Feb 20, 2010 | Procom QL300TYLA Heater
I have a ProCom FBN400TYLA vent free natural gas fireplace and want to convert to propane because the gas company wants too much money to hook up a line. Is this even possible?
Found the manual on line and copied directly from it:
WARNING
Models FBN400 are equipped for Natural
gas. Field conversion is not
permitted.
Models FBL400 are equipped for Propane
gas. Field conversion is not permitted
This should answer your question.
See if you can run the gas line or find someone to do it cheaper for you.
Nov 15, 2009 | Procom QL300TYLA Heater
I want to convert a QN300TYLA natural gas unit to
HI , I HAVE A PROPANE MODLE QL300TYLA I WOULD LIKE TO CONVERT TO NATURAL GAS , MAYBE WE CAN SWITCH PARTS.
Oct 08, 2009 | Procom QL300TYLA Heater
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Natural gas conversion
I have a similar problem. But, I want to convert it to propane. I have a 5 burner vent free modelMN300HPA. If your are handy. I would consider shipping you the parts inside mine to install in yours. These parts are very simple to remove after removing the access panels. I have taken mine out already. Called procom then to no less find out the propane parts needed are not sold by them. I think only the injectors (5) the main valve (regulator) and the pilot are the only things need to change. When taking out the pilot this is easly done, By removing the nut on the supply line. And then bending back the retaining tabs to then slide back the pilot then it comes out of the assembly bracket. Injectors are simply removed. Regulator located at the bottom is a simple remove. The only other item that might be questionable would be the valve that selects the amount of burners you would like to operate. And I would think this would be the same and not need removing. Let me know if I can help. I would like to get mine converted to propane. Thanks Tom
Oct 22, 2008 | Procom ML300TBA Heater
Procom ML200TBA
Propane appliances usually run on 10-11 inches of water column, this is about 1/2 pound of pressure. If the regulator you have is not rated for delivering gas at that rate, you will need to find one that does. If your regulator is rated for more than the 11 inches, most likely you could have damaged the appliance regulator that came with the heater. Check the propane pressure specified by the heater manufacture against the rated supply of your regulator and see if they match. Make sure the heater is rated for Propane and NOT Natural Gas. Check to see if the gas valve on the appliance is in the operate position and all valves are open. Bleed off the air in the gas line by holding down the pilot switch and keep attempting to light the pilot. It could take you a few minutes. If you hear and smell gas but the unit will still not light, don't chance at getting hurt, call a technician. Look to make sure there are no safety switch that may have triggered off not allowing the gas valve to operate. And make sure there is no obstruction in the heater?s gas valve blocking off the supply of gas. Always exercise caution when it comes to gas and if you are uncomfortable, call a qualified gas technician.
Dec 15, 2006 | Procom ML300TBA Heater
Heating & Cooling Logo
1,133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
