Question about ASUS P5B-E Motherboard
PC WONT START ASUS A7S8X-MX
Pc was left on overnite , in the morning was just black screen and would not turn off with the restbutton .So i unpluged pc power , now when i turn it the light in on in the onboard led on the asus a7s8x-mx and the pc will not start up when i press the start button .
I have removed the on board battery for 24 hrs then  tried again same senario .
i have removed all connetions to drives and removed all cards so it is only the mb connected with 1 stk ram and the amd sepron cpu( 8 months old )
the onboard led comes , it will not start from the start button .Also ther are no beeps at all .
Is there any one that can help please thank youcliee cgbalford@hotmail.com
I have the exact scenario and cannot figure out what's going on. I have the ASUS P5B-E and the problem i have now is that the computer seems "dead".
I have tested with new power supply, with and without memory, every possible combination and I consistently get the same thing.
1. Plug in the power supply
2. The mobo powers on it's own without pushing the power button on the box.
3. The power turns off automatically after about 3 seconds, then starts back up.
4. No post, no video, no beeps, nothing.
5. Same issue as the one comment above, the DVD cable plugged in provides no power to the DVD unit, but unplugged the DVD drive now has power.
I have removed the mobo from the box, cleared CMOS, and nothing will get the pc to boot. Has anyone solved this issue and determined the actual cause? I've searched and never really see any "conclusions". I'm assuming the mobo has gone bad and looking to buy another.
  • nteractive Nov 07, 2008
    The CPU fan runs fine. I switched out RAM, switched out Power Supply as well. Same symptoms. Weird, because i don't even get any warning beeps if no RAM, it just powers on, then turns back off, then back on...stays on and does nothing.
    I think i'm at a loss with this one and might chalk it up as a dead board. I've built many computers, and never had a mobo have symptoms like this.
    Just weird stuff. It's almost like it's stuck in some sort of sleep mode and will not come out of it.
    Thanks for you help
  • 5,568 Answers
Before you started disconnecting everything, did you notice whether the CPU fan was running or not? If it failed for any reason, the CPU is fried; none of them will tolerate the lack of cooling for very long. Also, bad memory can freeze a system for sure; if you have friend using compatible memory, beg him to let you swap yours into his board and vice versa. I've found failed memory more times than I can count and finally learned to substitute early and save a lot of time troubleshooting stuff that wasn't broken.
It pays to own a cheap multimeter so you can check the individual voltages from the main supply since they can very surely fail piecemeal and any outputs used must be there otherwise the train won't leave the station. Most supplies will have the available outputs lised on them. Don't know in which country you reside but in the US, you can buy a usable digital meter for <$20 US any time and if near a Harbor Freight, they often have them for 3 lousy bucks.
BTW, the CMOS backup battery is way too young to have failed; three years is pretty much a minimum and I have replaced 8 year old batteries that finally couldn't hack it any longer.
I hope you know to take precautions before touching anything inside to discharge any static charge you might have from carpets or clothing. Touching any part of the bare metal chassis after gaining access is adequate.
Posted on Nov 06, 2008
Hi, my sound card driver i cant find on line its ASUS A7S8X-MX Motherboard
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000
hope this helps
Apr 02, 2011 | ASUS A7S8X-MX Motherboard
Can't get a properly audio driver for my pc
If you motherboard is ASUS .and sound card is built in You can download sound driver from here.
Apr 05, 2010 | ASUS A7S8X-MX Motherboard
Windows xp multimedia audio controller not working for my motherboard asus a7s8x-mx series
Download separate audio driver for that particular Mobo, or the full driver set for it.
Mar 27, 2010 | ASUS A7S8X-MX Motherboard
Asus a7s8x-mx PROBLEM
HI there it sounds like your bios has reset if you download the quick start guide from the link bellow and set up your cpu type and set your hdd to auto detect hopfully that should get you booting .
If when you turn the pc off it looses the setting that you have put in and it fails to boot again you will need to replace the bios battery this can also be found in the manua and ony cost a quid or a cuople of dollars from you local pc store
http://uk.asus.com/product.aspx?P_ID=mng2ga5QWT68gbtY&content=download
Regards Al "alstech"l
Jun 29, 2009 | ASUS A7S8X-MX Motherboard
Startup f1 problem
what jumper settings on e what area ?
Jan 21, 2008 | ASUS A7S8X-MX Motherboard
I want 2 ASUS A7S8X-MX Drivers
Asus has a very good site at:
www.asus.com and you should be able to get your drivers there.
Nov 21, 2007 | ASUS A7S8X-MX Motherboard
So if i'm getting this correctly your computer will not boot even with just the basics.  Have you tried directly shorting the pins on the mobo instead of using the power button?  Unlikely problem but it would be an easy fix.  You might also want to take your power supply out and get it tested.  The geek squad at best buy will usually do that for free, or you can buy your own tester, or buy a cheap power supply.  If both the switch and power supply are good and you get nothing trying to start it up it means you probably have a bad mobo.  If your memory or cpu was bad and nothing else it would still boot up just without anything on the screen and might give you a series of beeps.  Well I hope i've helped and that you can get this fixed soon.
Oct 15, 2007 | ASUS A8S-X Motherboard
On board sound and graphics
Hi Keith, If you are using Windows XP: Right click on "My Computer"; Click on Properties; Click on Hardware Tab; Verify that there is no Red or Yellow marked entry; If there are, then drivers are not installed or there is a problem; The drivers for the Asus A7S8X-MX are available at the Download pages of the Asus site. In "Input Model to Search", type "A7S8X-MX", in Select Category, choose "Drivers", click on "Search Info". On the new page click on link"A7S8X-MX", click on the "All" tab. Listed are all the downloadable drivers. Hope this be of some help to you. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 04, 2007 | ASUS A7S8X-MX Motherboard
ASUS P5B-E Motherboard Logo
507 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
