Question about Roper RAS6233KQ Top Load Washer
Washer only washes on hot
Our washer works but only the hot water works. The cold water will not come out. Help! all of our jeans are starting to fade.
Angela
    President:
  • 2,712 Answers
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Posted on Nov 07, 2008
    I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
    Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
    check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
    if water starts to fill then change washer temp if washer has this.
    if water comes out on all settings water valve is fine.
    Check the water both hot and cold that it is turned on;at faucet.
    Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
    Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
    Cold/cold cyle wash water not cold
    try to do cold cycle first without doing warm cycle first
    Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore stackable washer wont work on Cold cycle only hot water
    Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
    Washing Machine2_bing.gif Problems No Water
    http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
    Washing Machine Fix Washing Machine No Water
    http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
    heatman101
    May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
    Hot/cold cycle works but w/out hot water
    I got my washer from a friend and his did the same thing. I have to put the washer on normal for cold water and heavy load for hot water.
    Apr 15, 2009 | Hotpoint VBXR1090B Top Load Washer
    Haier Genesis HLT364XXQ CAN'T GET HOT WATER WASH
    hey Paul, you don't have to wash anything in hot water. Hot water only wastes money and does nothing, in my opinion, to get anything cleaner. It does ,however set the stains. To kill any thing the water has to be 212 degrees [ boiling ]I have not used hot water for over 40 years and our clothes are coming out clean. Just set the machine on cold. I put a twoway spigot on my cold tap and put the hot water and cold water together incase someone breaks in and does my laundry. Barry
    Feb 14, 2009 | Haier HLT364XXQ
    Hot water doesnt work, switch to warm and warm comes out.
    If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
    Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Maytag washer
    It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
    Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag performa washer hot water runs continuously
    Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
    Regards Faggly
    Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
    Feb 19, 2007 | Maytag Performa PAV2200
    Roper RAS6233KQ Top Load Washer Logo
    174 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
