What to you mean by Monitor won't go on? Are you saying the power on the monitor will not turn on? Are you saying the Monitor is on, but there is nothing showing on the screen? Also it would help if we know what kind of computer and what operating system.
I ran into this very problem myself, the issue is that the monitor only supports 1280x1024 resolution MAX. Windows 7 cannot detect this monitor and so it does not know it is limited to this resolution, so Windows 7 is putting out a higher resolution at startup, thus the monitor tries to autodect for a second but then just goes blank because it doesn't understand (and can't display) the signal. The only solution is to use another monitor and adjust the resolution to 1280x1024 or lower, but I run into a problem where as soon as you remove the other monitor and restart, WIndows tries to "plug & play" the monitor all over again at startup. So you're best bet really is a newer monitor unfortunately, I only use my old Norcent monitor with my XP computer.
Hook a spare monitor to the computer, if okay! problem in the original monitor, if both show the same symptom, it means the Video Graphics Card in the computer is defective. If possible change the video cord from the computer to the monitor, sometimes these cords fail.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Sometimes it is not the monitor itself, the monitor gets the signal from your pc, what U could do is to upgrade your video driver to the latest version, try factory reset your monitor if the firmware was not providing a solution
press in the three buttons on the monitor ( + , - , and menu) at the same time , connect the power cable, that will reset the monitor to the factory settings
if you see that is helpful please don't forget to vote me
