Question about Canon imageCLASS C2100 Laser Printer
I have problems printing from my computer to my printer - Printer Error Message
Printer message is flashing and says: Cass 2 load plain letter
  • MJ21 Nov 06, 2008
    I did check the paper tray to see if it was out of paper and there was paper in the tray. I even put more paper in the tray to see if it was because it was too low and still have that error message.
  • 30 Answers
It sounds like the default tray it's expecting to pull paper from is out of paper.  Make sure the trays have paper, and that it isn't jammed.
Posted on Nov 06, 2008
Prints 2 pages and says to load paper
Somehow after adding paper you changed the paper size to B5. Change it back to Letter and it should resolve your problems
Apr 11, 2010 | Dell 2135cn All-In-One Laser Printer
Printer will not print after reinstall of software to macbook
yes ..if the sensor detect that there's is no ink or low ink..it display an error on the screen ..
to determine the status of the ink..
goto your desktop ..
click the printer driver software and select ink status..
good luck.
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
My LaserJet4250n Printer keeps printing a page recurrently. Except the former job is cancelled Manually, it prints the previous instead of the currently sent job. Moreover,it displays the following...
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Feb 25, 2009 | HP LaserJet 4250n Printer
'Load plain paper' message
Make sure that you have set the same paper type on both the printer driver and on the printer itself, using the on-printer menu. When I get this message, I usually had forgotten to change the paper type on the printer.
Jul 30, 2008 | Dell 3000cn Laser Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Error Message on Dell 5100cn
check the page setting in the printer as well as in the print dialog box in the, if the problem persists then you have to send it for servicing
Apr 29, 2008 | Dell 5100cn Laser Printer
Error Message 5C00
4 times is usually Automatic print head alignment
Set a sheet of plain paper (A4 or letter) in the ASF.and adjust.
Jan 14, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
you select the cassete of your printer it is saying to put paper by manual feed
Sep 11, 2007 | Dell 5100cn Laser Printer
Printing Issue
Test the driver. Go in the properties for the printer and set the number of copies to 4. Try to print a Windows test and and see if you get the same error message. If you do, then the issue is the paper settings in Printing preferences and probably needs to be changed to LETTER paper. If you don't get an error message, the issue is the application you are printing from. Make sure the application is set to letter under printer setup.
Sep 07, 2006 | Konica Minolta magicolor 2300DL Laser...
Canon imageCLASS C2100 Laser Printer Logo
93 people viewed this question
old marine
old marine
