Question about ASUS P4GE-MX Motherboard
500GB SATA with SATA to IDE adopter
SATA memory of 500GB
Hello
I have ASUS P4GE-MX Motherboard with intel P4 2.40A processor . I tried to upgrade by 500GB (SATA)memory with a SATA to IDE adopter. I am not able to boot and the processor make overheet alarm.
Anybody have solution pl.
rvijaynair2000@yahoo.com
  • 781 Answers
You have crossed wiring somewhere
Posted on Nov 06, 2008
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
I need the motherboard drivers for asus p4ge-mx, may os is xp,plsss help
check this link drivers for the devices on your Board - http://www.driverstock.com/ASUS-P4GE-MX-driver-download/6-9-10012/index.html
for your Board - http://drivers.softpedia.com/get/BIOS/Asus/Asus-P4GE-MX-1010001.shtml ^_^
Jun 03, 2010 | Intel Computers & Internet
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Pc upgrade
Hi ****, you can increase you system speed slightly (Depending on the total memory speed of the card), by adding an AGP 4x video card & setting your bios to boot to AGP. See page 2-16 in your manual. Change, Init Display First to [AGP]. Doing this will disable the onboard - integrated video card. (Doing this will also free your system memory which is used to run the onboard graphics card). Increasing your system memory to its max of 2GB will help as well. Here is Crucial's memory link for your board. http://www.crucial.com/store/listparts.aspx?model=P4GE-MX You should increase the CPU if at all possible to its max speed in-order to see an over-all increase of system performance. (This is not what you asked for, so I'll only include Asus link for supported CPU's, for the P4GE-MX motherboard). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P4GE-MX Don't expect lighting speed but you will notice game playing speed much better. Programs should load much faster, ECT. Upgrading the AGP must comply with 4x/8x (+1.5volt only). Please see page 1-12 in your manual. Looking for XFX video card is best because it carries a lifetime warranty. Try this link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150210 You can continue to search for an XFX Geforce cards. (Best on the market for their lifetime warranty). Good luck ****! Though the AGP slot is faster than a PCI slot, you may find an XFX PCI card with more video memory on it. Some even run DDR3 & DDR3 memory. Mike
Sep 14, 2008 | ASUS P4GE-MX Motherboard
Compatible processor
Yes, if you overclock you computer, I believe if you enter your bios of the motherboard, asus already has a pre overclock options. That is if your using a p4 2.8 ghz processor. You can not put a 3ghz processor and overclock it to a higher fsb, your motherboard will literally smoke up but, most motherboards probably can easily detect a non compatible CPU.
Sep 16, 2007 | ASUS P4GE-MX Motherboard
ASUS P4GE-MX Motherboard Logo
119 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
