I have a strange problem with an RCA DCR6300N, unit has been woking perfectly, then suddenly the remote no longer works (remote tested and is ok), the function buttons on the unit itself are fine on the DVD side, but are "scrambled" for lack of a better word on the VCR side, where the IR sensor is located. The eject button now does nothing, the DVD/VCR button ejects the tape, channel up is record, channel down is channel up, and the record button toggles the unit between DVD and VCR. So basically, the only function that is missing is channel down. All the switches are ok, I can find no cold solder connections, it has been unplugged for long periods to reset, all voltages appear to be where they should be, as far as I can tell without service info. Any suggestions would be greatly appreciated.
It has power to it..but when I put the dvd or vcr in and put it on the correct channels the it still...
(More)
It has power to it..but when I put the dvd or vcr in and put it on the correct channels the it still does not play after pressing play. I have tried all different ways..it has worked before..but I haven't used it in about 10 months..
When a disc is inserted it just spins and makes a motor working sound and does not read. Disc error...
(More)
When a disc is inserted it just spins and makes a motor working sound and does not read. Disc error or stop comes up on the display. We have tried DVDs that used to work and brand new DVDs no luck at all it reads nothing. I would love to be able to fix it or have it repaired. Any advise is greatly appreciated.
When you turn it on the main screen shows a line across it and colors. It is still new and was only...
(More)
When you turn it on the main screen shows a line across it and colors. It is still new and was only used a few times. Can you help?
