Question about Maytag CWG3100A Gas Single Oven
Maytag MGR5775QDW-TOP works ,broiler and oven don't
Put in new igniters on both gets hot still wont light
    Problem Solver:
  • 16 Answers
If you have lp makes sure the tanks are fill and unit is converted to lp.Same goes for natural gas
Posted on Nov 23, 2008
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts:
Jun 18, 2011 | Maytag Ovens
I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Oct 13, 2010 | Maytag Ovens
Oven Stopped Working..
It sounds like the igniter. The oven is not getting a spark to turn on, and heat up. We had the same problem, but changed the igniter, and it works fine. Good luck!
Jun 02, 2010 | Maytag CWG3100A Gas Single Oven
Even though the igniter is red, if you are not getting gas it is almost 100% sure that the igniter is simply not getting hot enough. A new igniter should get that valve to open and you will be baking like crazy.
Nov 30, 2009 | Maytag CWG3100A Gas Single Oven
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Aug 15, 2008 | Maytag CWG3100A Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Maytag CWG3100A Gas Single Oven Logo
225 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
