Question about Protron Televison & Video
DVD player wont open - Protron Televison & Video
  • 903 Answers
Unplug the dvd from the electric outlet, take the cover off and see if there is a dvd trapped inside causing it to stop opening.
Posted on Nov 06, 2008
Dvd player wont open
try a paper clip opened and put on dvd door hole (small hole), and push slowly the paperclip inside and realease the dvd door to open, normaly is a defective dvd laser mec. and needs to be replaced. send to repair
Jan 03, 2010 | Panasonic DVD-RV26 DVD Player
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Mar 29, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD player wont open says E:26:00 then shuts off
Solution #3 worked for me.
http://www.fixya.com/support/t127790-error_message_e_26_00
Mar 13, 2009 | Sony OPEN BOX SLV-DP550P DVD/VCR Combo...
I cant open the dvd tray on my SamsungDVD-P241
turn off unplug ...turn upside down...this may dislodge it disk...gently shake...this may take a few tries
Dec 10, 2008 | Samsung DVD-P241 DVD Player
the door will not open at first it would open and close real quick, now it will not open and then it quits too, thanks jon
Jul 02, 2008 | Sanyo DWM-380 DVD Player
DVD tray WONT OPEN
unplug it and try it again, if that doesn't work see if theres a pin hole where you can push a paper clip in by the tray area.
Feb 26, 2008 | Toshiba SD-V394 DVD Player/VCR
Malfunctioning DVD player
that is normal for laser to do that.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 03, 2008 | Cyberhome CH-DVD 300 DVD Player
Look on the bottom of your player. Between the two front feet you should see a narrow slot that is about 1 1/2" long (it should say "emergency hole". Shine a light into the slot, you should see a black pin about as big around as a pencil lead. Carefully push this pin in the direction of the arrow. It should release the drawer and allow you to open it.
Aug 27, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
64 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
