Polaroid Flat screen TV. Turn on the set and no picture. Blue indicator light indicates the set is active, but no picture. Try to turn off and the blue light stays on. I then unplug and plug back in then try again. Sometimes the picture will then come on, most times I have to unplug and replug about 5-6 times then picture will come on. When it comes on, there is a buzz that fades away after about 10 seconds.
SOURCE: Picture then fades to blue.
I just fixed mine. I read other posts that suggested this and it worked. On the front of the set at the bottom of the speaker cover are 2 caps, one on each side. Remove those caps to find 2 screws, remove screws and then remove that cover. Behind that is a panel with 4 screws and remove it. You will see a box with 6 knobs, 3 on top 3 on the bottom. Top are focus and bottoms are voltage to each lamp. Blue lamp is left screw, green lanp is middle screw and red lamp is right screw. Counter clockwise lowers voltage(very small adjustments. So if your screen is turning blue turn the left screw just a littleat a time. I also had red and blue lines on my screen so i turned them a little as well and they are gone. Give that a try, it worked for me.
Posted on Jun 02, 2007
SOURCE: new Sceptre 37" LCD TV does not turn on
normally the a-v cables are color coded the white goes with white the red goes with red and yellow goes with the yellow and when putting it in the dvd player if applicable it should be the same way did your tv come with a manual showing you how to hook it up
Posted on Aug 09, 2007
  • 21 Answers
SOURCE: How to get a picture and sound
if you still have a problem (and the tv!) email me at gmail.com
Posted on Aug 31, 2007
  • 39 Answers
SOURCE: Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Posted on Dec 14, 2007
Slinteriors
  • 8617 Answers
SOURCE: RCA Television D52W14
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
Tv has power, but no picture
I hit the button on the sidea and it went to channel 17 I got it back to channe 3 but it still says no signa I do not have a Polaroid remote
Sep 27, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
My polaroid TLA-04011c wont come on at all - it has a blue LED lit, indicating the set is on, but theres no picture whatsoever
First turn on and check with flashlight 2 in. from screen and see if there is a picture. If no picture then open back panel door by taking big black screw out of middle and 2 screw at bottom of panel and slide panel downward, pull off and unscrew metal plate and you should see bad caps in this set, this is what have to be replaced.
http://www.youtube.com/watch?v=EDylk9ezQtA
Dec 28, 2010 | Polaroid TLA-04011C 40 in. LCD TV
I have a polaroid 42 inch flat screen and the screen is solid blue when i plug my cable in it is black I can here sound but no picture it is a 2007 module tlx-04240b
Make sure all the connections are correct, a "blue" screen indicates no-signal, black indicates some type of signal is getting to the tv. good luck Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Televison & Video
Bush tv 20" lcd tv LCDS20TV006/A - blue screen no picture availab
DOES THE MENU SCREEN COME UP? IF YES TRY ANOTHER INPUT. A BLUE SCREEN IS USUALLY INDICATIVE OF THE SET NOT SEEING A VIDEO SIGNAL.
Apr 10, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Blue power light flashes No picture on a 37 HDTV/LCD Polaroid -
this might help
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Dec 29, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid lcdtv flm-373b
its the problem in the power supply board of your tv. any of the capacitors or ic are loose on the board.check it out and make it proper,
Oct 26, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Won't turn on
Try pressing the "channel +" button on your TV.
Sep 30, 2008 | Polaroid FLM-3232 Television
Polaroid Flat Panel TV FLM 373B
I had the same problem with mine, and figured out how to repair the control box. If you would like to have me perform a service on your set go to www.mikecampagna.com/Polaroid
Apr 13, 2008 | Televison & Video
Nov 09, 2006 | Protron PLTV-32 Television
Televison & Video Logo
Top Televison & Video Experts
