Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
Infocus image problem
I have a brown "bar" running down the side of the projected image on the screen. It almost looks like a burn mark...but is not on the computer screen just the projected image
  • Anonymous Feb 10, 2009
    I have the same problem. Brown "bar" at right side of screen. A shadow about 5 inches wide
  • cudzilotpc Apr 10, 2009
    Same Thing!! Brown bar on right side of the screen. I Have about 600
    Hrs on the bulb when this started. I don't know if it the bulb or the projector?
    Scholar:
  • 167 Answers
That is caused by a collapsing light pipe.
This is a mirrored glass square component that is located directly behind the color wheel. It is comprised of 4 mirrored section approximately 40mm x 8mm that are glued together with a hi-temp adhesive to form a square. The artifact you see is one of these mirrored glass section's has come unglued and has moved inwards blocking one edge of the image. The edge of this shadow is not shar because this failure is not at a focal point.WHEW..all that being said it's possible to re-glue it if you are electro-mechanically savvy and have steady hands. If you need to take it to a service they will most likely just just replace the complete DLP engine (the whole optic assembly) Hold on to your wallet!!
Cheers
Posted on Jan 16, 2010
There is a line down right side of projected image, from top to bottom, different computers. Thanks Loren
I have a 2 inch white line down the middle of the screen from my Infocus DPL projector.
Can you help?
Paul.
Nov 29, 2010 | Optoma EP771 DLP Projector
My projection is in Black and White
I have seen this with a number of X1's and yes it will need to go into service and knowing what the cost of repairs was and the age of the x1 i would start looking for a new projector.
Jun 04, 2010 | InFocus X1 Multimedia Projector
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Lamp comes on, fan running at a very high speed
if the lamp is on and no image, you have a main board issue. you'll need to replace it.
Mar 18, 2010 | InFocus ScreenPlay 4800 Multimedia...
We have an Infocus X3 unit that is getting a yellowed image
the colorwheel is collapsing and needs replacing. you can get one from any infocus authorized service centers and do it yourself or have them do it. if you are in ny, try av solutions. they've always done good work for me.
Oct 02, 2009 | InFocus DEMO X3 1600LUMEN XGA DLP MMPROJ...
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projected image has a shadow in the corner
Most probably a water mark symbol...kind of thing(bcos of the comment by one guest, stating occurance of the problem commonly), why don't u write to the support for projetcor?
Also, if not within warranty, please do check for any dirt / paper tag / breakage of glass (are u sure they have replaced the unit, during the complaint for trans error)
bye
was his helpful?
Have a nice day
Feb 12, 2008 | InFocus LP70+ Multimedia Projector
Infocus projected image is distorted
check the screen resolution settings in visa it maybe different than the desktop settings.infocus can execpt many resolutions but not all. try 1280x1024
Jan 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Looks like pen marks on inside of screen
What you are decsribing sounds like your picture tube or tubes have been scored (permanent burn marks on the picture tube phosphor). The sure way to tell is to remove the front screen and look into each of the three lenses while the set is on. You will see a black image of your pen mark within the picture. Did you recently have problems with convergence or the set shutting down (turing off by itself for no resaon) ?
Nov 12, 2007 | Toshiba 50H82 50" Rear Projection...
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
309 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
