Question about Frigidaire FRS26KF5C Side by Side Refrigerator
Frigidaire frs26zrf My fridge part won't cool. Electric to both sides fine and freezer works good. Fridge side not cool at all but warm.
  • 833 Answers
SOURCE: Frigidaire Fridge PLHS69EESS2
Could be a jammed fan or something could have moved inside to block the opening. Some units have deflectors in the openings...did one of those cover the opening on the fridge side? Did you overpack your freezer and block the air flow from there to the fridge?
Posted on Jan 03, 2008
mikedurland
  • 481 Answers
SOURCE: fridge / Freezer no longer cooling
 Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
joecoolvette
  • 5660 Answers
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Posted on Jul 05, 2009
  • 239 Answers
SOURCE: My frigidaire FRS26ZRF is not cooling in the
Replace it, it's only $13.00
Posted on Sep 01, 2009
dmftrucker
  • 1922 Answers
SOURCE: Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Posted on Nov 02, 2009
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Frigidaire Refrigerator is warm on top of the frig and freezer but fine on bottom.
Remove the rear lower panel on the unit check to see if the compressor is hot or if its running, should feel the vibration, also listen for any clicking noises.
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Frigidaire frs26lh5dso freezer works great, fridge side is warm.
make sure door to refrigerator is all the way up, so when it is closed it turns the cooling part on. I have to check mine all the time and screw it up if it's down, which is quite often. Mine is a side by side and I just make sure it's even with the top of refrigerator and even with the freezer door.
Jul 16, 2012 | Frigidaire Refrigerators
Oct 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Nov 09, 2008 | Refrigerators
Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Mar 30, 2008 | Frigidaire FRS26ZSG
Dec 29, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
216 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
