Question about Hayward H Series Electronic Ignition 250,000 Btu Pool Heater H250ped2
Hayward Spa Heater ignites for 2 seconds and shuts off.
I have a Hayward H 250ED1 - When I turn it on, the flames fully ignite for 2 seconds and turns off, I have replaced pressure switch and bypassed all sensors and switches. I changed the sand in the filter 20# type. I am guessing I have a few solutions left: Replace Electronic Controls (spark Ignitor), the gas valve or maybe it is clogged with calcium. Any suggestions
  • 61 Answers
Sounds like this is a flame sensor issue. It is not detecting the flame.
Posted on Apr 04, 2009
Hayward heater h150 ignites and shuts off
check pilot generator if 500 millivolts to gas valve turn on switch if lowers should light if not check wires could be loose make sure flame sensor is above burner if not it wont sense flame
Jul 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
H400ed2 IF
(IF- Ignition Failure) It may be your flame sensor failing to recognize that the heater has fired. This will tell the gas valve to close if it does not detect a flame.
Dec 06, 2013 | Hayward H Series Pool & Spa Heater...
I HAVE PROBLEM WITH HEATER IS SWOING 1F IN THE SCREEN
YOur 1f code is actually a IF code which stands for "ignition failure".
This can be caused by many things, but the most likely is either the ignitor has failed, or the flame sensor has failed.
Make sure the gas manual gas valve is open. Remove from panel so that you can see the ignitor.
Turn off power, then turn back on. After 90 seconds, the ignitor should start to glow red hot. If this is not occuring, then it is likely the ignitor or ignitor wiring.
If the ignitor does glow, then the heater ignites, but still goes off showing the IF code, then it is the flame sensor.
If the ignitor glows, and the heater does not ignite, it is likely the gas valve or ignition control.
As stated above, the ignitor is most likely.
Dec 30, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pool heater gas fire lights up and turns off 10 secs later
Assuming you don't hear any banging noises, that cycle is by design. There is a fault. 2 possible causes are the ignition board is bad, or the ignition sensor is not returning a voltage indicating the flame is lit. Take this out and put the ignition piece on your stove flame. Check for voltage while on flame (DC millivolt setting on multimeter). Put one probe on ground other on sensor lead. If it doesnt have voltage this is bad. If you do, its possible your board is bad.
Apr 26, 2010 | Hayward H Series Induced Draft Abg 100,000...
The heater fires up for about two seconds then turns off. The filter is clean!
most likely your flame sensor needs to be cleaned with fine emory cloth.sensors sometime become oxidized or corroded. once burner ignites,if flame is not sensed signal is sent to shut down valve as a safety precaution
Jul 16, 2009 | Hayward H-series Electronic Gas Pool...
Fails to ignite - fan blows for 15 seconds, then 2
i had the same problem it turned out to be an old regulator valve on the gas meter wasnt allowing enough gas to reach the heater. i had to have the gas comapny come out. they changed it for free.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
H250 inground pool heater turns on 5 seconds shuts off flsahing 1f
This is a code for ignition falure. If you are getting a pilot then it means your Ignition module is not sensing the flame and shuting the gas down. This could be pilot wire burnt and grounding or a pilot flame not reaching the sensor or a bad ignition module. This is the expensive part so look into the other things first. Good luck.
Jun 26, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Heater turns off a few seconds after ignition
Flame rectification is made by a ground signal in the heater. Wet heater = better grounding = longer running time. Look for rusty areas in and around the ignitor area and wire brush them off so the signal that the ignitor has a pilot flame on can get to the board. The only other problem could be the control module itself not recognizing the rectification signal which would mean a new module.
Jun 18, 2009 | Hayward H Series Pool & Spa Heater 400k...
H400 Lights, but turns off after 2 seconds
There may be a pressure regulator internal to the unit that has failed. For safety, most gas appliances monitor the output of the internal regulator; in a situation where the gas pressure is unstable, if the main burner does not ignite within a finite period, they will shut down to avoid a buildup of unburned gases that could pop your windows out (or worse) if the ignitor keeps trying.
Jun 17, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Electronic Ignition 250,000 Btu Pool Heater  H250ped2 Logo
892 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
