Question about Cuisinart DCC-1200 Coffee Maker
I have a Cuisinart DCC1200 serial # 50824h. It will not brew. There is a small light on 1-4 when pushed,and clean light when pushed and when the main switch is pushed up nothing when pushed down if small 1-4 etc had been on it will go off.
  • 8,596 Answers
Unplug for longer than 15 minutes to reset. This one is slightly out of warranty - by about 4 months.
Posted on Dec 15, 2008
Is there a fuse? How do I fix it?
It might be dead, but...
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place - especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement - call Cuisinart as they have a longer-than-standard warranty.
Feb 25, 2016 | Cuisinart Brew Central 12-cup Coffee Maker
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Clean light stays on,help me trouble shoot
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
If your Cuisinart is one that is missing the Self-Clean function, just brew the vinegar and water like it is coffee by using the brew function.
Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
The coffe pot will not turn on it has power the clock works but will not brew
My dcc1200 doesn't always turn on. When it does, it doesn't finish the brew. How can we get it fixed
Sep 13, 2009 | Cuisinart DCC-1200 Coffee Maker
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I just received my cuisinart coffe maker DCC1200 and I wanted to brew a pot of coffe but I am unable to open the glass carafe to obtain my coffe filters. Is there a specific way to open this? Your...
Hmm. Better late than never. Just got home with ours. Same problem. Called Cuisinart 800 number. Catch is on top of handle. There is a slight lip on each side there. Pop it up with pressure on both sides simultaneously. To replace, line up lid carefully with top of carafe and press firmly until it pops back on.
Jun 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Self clean feature on coffee pot
here is the link to the manual http://www.cuisinart.com/share/man/25_man.pdf page 8 - looks like you have a calcium buildup - descale overnight using vinegar/water 50% if the self clean feature is not able to deal with the problem. hope this helps :)
Mar 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
219 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
