Question about Sony KP-57WS500 57" Rear Projection Television
Sony kp-57ws500 light blinks 8 times
I have a sony kp-57ws500 the light blinks 8 times. found what i found the common fix is the t8005 trans. but what i am not sure of is the red and green tubes light up for about 5 sec. then go back out and the blue will not come on at all could the blue tube be the problem
  • 11 more comments
  • brian mccarty Nov 06, 2008
    icheched all the wires going to the blue tube all are pluged in. what transistors are you talking about
    audio problem will that affect the blue tube
    if the d board need to be replaced why is the blue tube not coming on like the others are
    ok as i was checking the 12v and the 200v on the board blue tube found r7324 is burned can i replace this only or do i need to replace the tube also what is the spec. for r7324
    the blink codes is 8
    ss
    r7324 spec
    need the spec for resistor r7324
    if i replace the resistor will that fix the blue tube
    when i turn the power on the screan turns yellow for about 5 sec. then the tv turns off and the light flashes 8 times if the blue tube does not come would it cause the tv to give the blink code 8 or would there be a different code for the tube
    ddddd
    thanks for the help i will replace the resistor and see what i get
    i got the cb board off and found that r7324,r7326,r7301 all have burn holes in them
    Scholar:
  • 44 Answers
I found this:
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
You can also try this:
You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode.
To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power.
This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
Posted on Nov 06, 2008
    President:
  • 1,952 Answers
The light should blink x times, pause and repeat. Report that number here. The blink code is an internal indication of the problem circuit.
  • mohammed marika thambi
    mohammed marika thambi Nov 06, 2008
    This is a convergence problem and is either bad connections on the
    convergence ICs or defective ICs. Try resoldering the pins on the ICs
    first. If that fails to correct the problem, replace the ICs. These
    are large black ICs attached to a heatsink and should be marked STKxxx.
    Something as simple as bad connections that change internal resistance
    can cause odd symptoms like this too. I don't have any specific
    causes. Can you solder? Try resoldering any connections on the boards
    that appear to be grainy or have rings. This problem sounds like a
    high voltage change somewhere along the line. It can't be with the
    flyback as that would show up on all tubes.
  • 899 Answers
This is a high voltage error and it probably has to do with the blue
  • jason Nov 06, 2008
    the reason for them all going out is the t8005 , the protect circuit is shuting the tv down to avoid further dammage
    you can try but if it goes then you need to replace it again and the t8005
  • 10,594 Answers
Check 12 volt (CN7302 pin 6) and 200 volt (CN7303 pin 1) at blue CRT board (CB)
Let me know the result to guide you further.
Thank you.
  • 6 more comments
  • Shahid Electronics
    Shahid Electronics Nov 06, 2008
    8 blinks means problem in High Voltage and T8005 can also be a cause as it is an important part of High Voltage area.
    Do you see any arcing in Blue CRT?
    R7324 is 1K and 1/2 watt resistor at G1 (pin4) of blue CRT.
    Let me know do you see my comments to help you out?
    Below is picture of CB Board. Hope this will help you.
    Turn picture to clock wise for better view.
    I don't think R7324 replacement will fix blue CRT as this question is still there why R7324 was blown?
    You just can see what is happening with Blue CRT after replacing R7324.
    I'm afraid Blue CRT might be defective.
    Code would be different and it should be 5 times (white balance failure) but as I said before, seems Blue CRT or CRT Connector is defective.
    Check circuit picture here.let me provide you connector part number.
    Thanks for rating my solution.
    CRT Connector details are as under...
    CN7309 1-251-182-11 SOCKET, CRT
    It is available in Parts Store and price is approx $5
    Good Luck.
    Ok, here are details of all resistors:
    R7324= 1k 1/2w
    R7326= 220 ohms 1/2w
    R7301= 10 ohms 1/4w
    Need further help, let me know please :)
    Genius:
  • 1,550 Answers
8 blinks indicate - Audio circuit is damaged in your unit .
    Genius:
  • 1,011 Answers
Dear,
was it happened every time when u turn it on...
or it works fine sometimes
regards,
  • 1 more comment
  • SALMAN NASEER Nov 06, 2008
    dear,
    High-voltage error" and the probable cause location listed is"T8005 is faulty (D board)". T8005 is the fly-back transformer. Probably your best bet is to replace the D board.
    regards,
    it could be possible that in Dboard the blue tube is not directly infected..with its components
    by the way, check as my fellow "welcomejee" suggested..
    regards,
    Sergeant:
    Novelist:
  • 196 Answers
Replace all the transistors and it should work only after that.
or it will blow the unreplaced transistors.
  • mmechanics Nov 06, 2008
    if the blue tube is not coming ON completely then it has to be replaced.but once check out if the tube is connected properly with its wires if there is any short it may come even if you replace it with new.check out.
    if every thing seems to be proper on the board.then rerplace the tube.also check the allignment of the tube which u r going to change.
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
51ws500 sony shuts down and standby light flashes 8 times
Eight blinks points to an audio output problem. The unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Hope that helps.
Feb 20, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
No sound or screen
8 time flash shows problem with T8005 (flyback transformer, horizontal transistor) in D board. Service manual says ...
High voltage error 8 times • T8005 is faulty. (D board)
bye
Sep 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57WS500
The flyback transformer is defective when the LED flashes 8 times. The FBT is located on the main board(D board).
Location of the part is T8005 and the Sony part number is 1-453-285-41
This part is available from this website.
This type of repair might not be a DIY due to the danger of working with devices that generate high voltages.
Sep 03, 2008 | Sony KP-57WS500 57" Rear Projection...
KP-57HW40 w/ 8 Blinks
8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
Dec 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
317 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
