Question about Garmin GPS
It always takes a while (feels like forever or never) for my GPS to locate or find a place. Why?
  • 48 Answers
Unfortunately, this is normal :(
-all the companies & units I have ever used l share this 'issue'....which as you suggested is irritating
The GPS must 'triangulate' the information it receives from the satelites (minimum of 3) inorder to calculate your location (lat/long& elevation)
-as they need a clear vision of the sky be sure to stand in a location, away from buildings, trees, and even cloud these impede the signal and therefore the speed & accuracy of the calculation....which as you know can take awhile (up to 10+ minutes if it has been off for awhile)
-if you use it quite frequently, the units do not 'forget' the data as quickly
-this is same as a computer 'caching' information
-before I teach a lesson using GPS ...I go outside, turn units on to speed up the we do not have to wait (most units do not function inside buildings, even if they have lots of windows)
-hope that helps
Posted on Nov 06, 2008
Micro sd card wont click into place garmin nuvi 2589
On some units, they won't click. You slide the micro SD card into the slot and you will feel a slight resistance. Continue to slide the card in until it stops. It will only slide in one way. This is exactly how the micro SD card slides into a standard SD adapter. There is no click. If you connect the GPS to a PC using the USB data cable, your PC should recognize (2) memory devices; (1) The GPS and (2) the SD card. It may take a few moments. Wait a few minutes until you see both appear in Windows. Always select EJECT or SAFELY REMOVE before you remove the USB data cable.
Feb 28, 2016 | Garmin nuvi 2589LMT 5" GPS with Built-In...
My route 66 champion 6000 satnav has no signal, just says no GPS
When a GPS device is switch on on a different place it was switched off, I could take some minutes before it finds enough satellites And when you are in a building, or close to high buildings it could take forever, because the receiver only can receive the very weak satellite signals, if it is outside and has a clear "view" of the satellites.
Jul 05, 2014 | GPS
Where do you mount your GPS? What part of the window?
There's no specific place to mount it. however, I feel that the best place to mount it would be in line with eyes and the external line of the road. This way you keep your gaze always inside the road minimizing distraction risks.
Jan 26, 2012 | Magellan Roadmate 5045 3065 3055 3045-LM...
Takes forever to locate satellite
I have a garmin NUVI i wish i can email you a picture but i cannot. This proves nothing tho but to tell you i had the same issue and the issue was the software got corupt on the device due to a bad battery, Not this is not always the case so i do welcome you to investigate but at least give me some face time with my arguement here. these unit are battery powered and there little small pocket pc so to speak there software is stored into Flash memeor inside witch can become corupt and take forever to load the gps mosule you are having issues with.
things to give a shot here.
1. corupted software try a complete reload.
2. how long you had that battery? Couple years? well betterys have a certain life cycle recharges.
3. if after a reload and battery the unit still does not work you can entertain repair.
thanks for asking your FREE questions please keep in mind that it was free at no charge to you. all we ask before you leave is to rate and leave feedback to keep these free answer alive. without your feedback experts tend not to answer freebies anymore and go for the paid questions. thanks
Apr 28, 2010 | Garmin nuvi 200W GPS Receiver
My gps saids i am always in new york even though iam in maryland never moves from new york
If it is constantly on a singloe map location and never cuts in to navigate thjen suspect that
1) the antenna is afunctional, disconnected, or not working to lock onto satellites.
2) The chip that locates and communicates with the satellites is dead.
If it always shows a particular location when started, but does navigate to where you ask it to take you, but always returns to the base location when tuened off and then on. The program in your home address or in SETUP program your location and time zone to have it always start in Maryland.
Jun 07, 2009 | Pioneer AVIC-N3 GPS Receiver
Having problem locating gps signal
try doing a GPS reset, exit navigation, tap on setup and go to gps reset, this may clear old almanac data from the gps receiver. if not, you may have one that is loosing its memory.
Dec 09, 2008 | Fine Digital FineDrive 400 GPS Receiver
Satelite search takes forever
Hello bertvanjbert,
In order for your GPS to calculate its own location, it needs to receive data reports from four or more GPS satellites. This process is normally pretty fast. However, this assumes that the GPS has a clear view of the sky.
Obstructions such as tall buildings, trees and local terrain such as mountains and hills can affect your receiver's ability to "see" the sky. This is also true of GPS units used indoors or inside of a vehicle.
A GPS receiver without a clear view of the sky can take a long time to get a fix on its own location. The process can also take additional time if the GPS has been powered off for an extended period of time or if you have travelled a long distance (greater then 500 miles) since it was last turned on.
Hope this helps!
"Go Ahead. Use Us."
Jun 26, 2008 | Garmin nuvi 250 GPS Receiver
Takes forever for garmin 260w to locate satellite signal
it takes forever to get a gps signal on my garmin 260w , can you help please . thank you .
May 25, 2008 | GPS
GPS Logo
52 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
