Question about Whirlpool LSQ8000 Top Load Washer
Washer will not spin
The washer motor runs but the basket will not spin up unless empty. when the basket does spin up (empty) i can stop the spinning basket by hand. there does not apear to be belts on this motor (direct drive link)there are what apears to be friction pads (look like break pads) that are spring loaded on the drive unit. they look warn down. could this be the problem. any help would be apreciated. Thank you
  • stevemcd88 Mar 30, 2008
    I have a Whirpool Ultimate II Washer... my problem is that the basket will not spin but just makes a loud noise as if it's not "catching" the spin mechanism. I'm wondering if this is a quick fix or should I try to buy another new washer..any thoughts appreciated
  • cindeeelou Mar 16, 2018
    Sounds like the agitator gears are completely worn out, it is $12.00 for kit and is easy to fix.
It is a $12.00 part. You need a agitator kit, because you wore the teeth off the agitator, that is why it won't spin.
Posted on Apr 03, 2008
    President:
  • 878 Answers
Josh, sounds more like the drive block or spin tube that is at fault. I will attach photos of each...Catriver..post back.
Posted on Oct 13, 2006
  • Ron Marek
    Ron Marek Oct 13, 2006
    First picture is the drive block, the spin tube top fits in the 2 notches. Second photo, spin tube or basket drive
Washer pumps but half the time it won't spin unless you give the basket a little push. I use a small magnet to keep the lid relay closed. Once I give the basket a little push, the washer starts to...
Quite likely the spin motor is a capacitor start type motor and has a capacitor to start it (by placing a winding slightly out of phase with the rest of the motor in turn encouraging the movement of the motor). When it reaches about 200 RPM the capacitor is disconnected and runs without it.
Maybe the start capacitor is faulty or the internal switch/electronic control is faulty?
Aug 30, 2011 | GE WPRB8050D Top Load Washer
My washing no start and display view f34 Thanks
The F34 code normally only occurs when you are trying to run the CLEAN WASHER cycle. The washer should be completely empty of laundry when you are attempting to start this cycle. If the washer is empty and you are trying to run this clean washer cycle then you could have a friction problem with the spin basket that is causing the F34 code. Try turning the spin basket by hand with the washer empty and dry. The basket should turn relatively easily. If the basket will not spin easily you could have a problem with the bearing in the back of the outer tub or you could have an item stuck between the spin basket and the tub inside the washer.
May 04, 2011 | Washing Machines
Error code f-51
The F51 code indicates that the control is not detecting proper motor rotation in the washer. This can be caused by overloading the washer, a fill problem or even a toy or item that is stuck underneath the washer that is preventing the motor from spinning properly. With the washer empty, see if the spin basket rotates freely. If you detect resistance, then you check between the basket and tub for an item that is stuck in this area.
Feb 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
The Washer did not spin
MOR PROBELY THE CUPLER WENT OUT IS A 3 PEASE 2 WHITE AND 1 BLACK PART IN BUTTEM OF WASHR BETTEN THE MOTOR AND TRANMISION OR CK LID SWITCH. GOOD LUCK
Jul 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer doesn't spin
Hello skull1829 ,
Was the Clutch/One-way roller bearing changed out for dc/UC errors in your FAV6800AW/FAV9800AW?
If you start a Spin Only Cycle with an empty wash basket will the wash basket spin up CCW and complete the cycle? Lift the washer top from the base a few inches to observe the wash basket CCW rotation in spin cycle. If the clutch spring is broken or end pins of spring aren't seated the tumblers will rotate and the wash basket will rotate slowly CCW.
IF the wash basket won't spin up can you pull the front cover off and insure the motor will rotate the clutch pulley CCW in a Spin Only Cycle? Let’s try these few basic tests and get some feedback for troubleshooting.
Rich
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
F51 & F72 Codes
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops mid cycle while filling up and locks the door and reads f51 and we have tried everything from unplugging it to stopping and restarting it nothing works
Mar 23, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Won't Spin Without Assistance
It sounds to me like either there is an excessively heavy load in the washer and the unit simply isn't strong enough to get it going, or more likely the clutch mechanism/gearbox is malfunctioning. They use a clutch mechanism to allow the motor to run at a constant speed while the basket can start rotating slowly and pick up speed with time. If this clutch mechanism or gearbox isn't performing properly, the basket won't spin. It's not your motor or safety circuit since the basket will turn if given a little push.
Mar 10, 2008 | Washing Machines
My direct drive washer spins slow
Always rule out first: Unsorted, too big or off balance load, too high or restricted drain, oversudsing or water not draining completely out before going into spin. Otherwise the brake could be not releasing fully or the clutch lining is worn. Pull the basket and transmission and check the basket drive.
Nov 11, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer won't agitate
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Nov 27, 2006 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool LSQ8000 Top Load Washer Logo
130 people viewed this question
Dan Webster
Dan Webster
Sal De
