Question about Mitsubishi WD62628 62" Projection HDTV
Lamp replacement Any idea where to find the reset button on the projection TV.
On front of tv next to lamp lite need to reset with small pin or paperclip
Posted on Dec 28, 2008
How to reset the lamp meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
Tip
How to reset the lamp timer for Panasonic DLP TVs.
When you replace the lamp on a Panasonic DLP or LCD TV you will need to reset the lamp timer to zero for the TV to reset the lamp timer and extinguish the change lamp indicator.
There are two methods used depending on which model TV you have. The older units use the first method and newer units use the second method. You can tell which method you need to use by whether you have a PIP and/or SPLIT button on your remote. If you have them use the first method, if you don't use the second method.
Method number 1 (for older units):
Follow the procedure below. You use either PIP or SPLIT button depending on whether your remote has SPLIT or not. Some do not.
Perform lamp timer reset only when the lamp has been replaced. The idea is to know when to replace the lamp before the end of it's life when it could explode or short out causing a hazadous condition. If you reset the lamp circuit at any other time the replace lamp warning will not come on at the recommended interval.
Be sure the power cord is plugged into a properly grounded wall outlet.
Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the
PIP or SPLIT button on the remote control at same time for more than 5 seconds.
If your remote does not have a split button you use PIP, if it has a split button, you would use SPLIT.
When reset procedure is complete, the screen on the TV will indicate that the lamp has been reset. When lamp time reset is finished, the LAMP indicator goes out.
Method number 2 (for newer units):
Press volume down on the TV and the zero button on the remote at the same time for longer than 5 seconds and it will reset the lamp to zero.
These procedures should reset your lamp timer and you will be good until the current lamp fails or the change lamp indicator illuminates again signalling that it is time to replace the lamp. Three to six years on average depending on how much you run the unit per day. Do not ignore the indicator. Change the lamp immediately to avoid further damage and expense or worse.
Thanks for using FixYa and for the great rating.
hardrocko
on Apr 11, 2010 | Televison & Video
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Sep 16, 2009 | Panasonic PT-60LC14 60" Rear Projection...
Replacing the projection lamp
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Replacing lamp in rear projection tv
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
May 09, 2008 | LG RU-52SZ30 52" Rear Projection...
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Mitsubishi WD62628 62" Projection HDTV Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
