Question about HP LaserJet 2100 Printer
Ghosted image Hi all. Been having a problem with my 2100 where it reprints a 'ghost' of the current page several times. I thought it was the fuser and bought a replacement online (albeit, a used one). I'm having the same problem now. So I'm wondering if 1) there's something else going on or 2) if I got a bum fuser and now have two non-working ones... Ideas? Here's a link to the image... http://gallery.me.com/djfern#100016
  • djfern Nov 06, 2008
    Hey guys, I did a little check, based on another tip from this site.
    I printed a page through manual feed and then turned off the printer before it reached the fuser.
    Then i took the toner cartridge out.
    The image on the page, right out of the toner, has the ghosting on it.
    Do you think that getting a new toner cartridge will fix the problem?
    Genius:
  • 1,605 Answers
Usually the ghosting of image is due to bad fuser. since the fuser is not hot enough to fused the ink to the paper, the image is then transfer to the roller from the paper, you have ghost.
try to clean the rollers, inside of the machine and the paper pickup roller.
if you suspect the roller is not clean, you can change it. get a maintenance kit form HP. or other reseller.
Posted on Nov 06, 2008
    President:
  • HP Master
  • 1,314 Answers
Okay, this is going to be difficult to isolate.
From the service manual: "Repetitive print defects usually are associated with a specific roller within the printer or the Toner Cartridge. Use Figure 7-1 to isolate the cause of repetitive print defects. Align the first occurrence of the defect with the top of the “ruler” (at the top or bottom of the misprinted
page), and measure to the next occurrence of the defect to determine the roller in question.
When the defect pattern matches the pattern of the ruler, replace the indicated roller."
I can't post the ruler from the service manual here, but it gives some measurements.
Start with the initial point where the occurence started then measure down to the next occurence.
If it occurs at 38 mm, then it is your primary charging roller.
At 42 mm, feed roller.
44mm, registration roller
46mm, transfer charging roller
50mm, developing cylinder
63 mm, pressure roller
75mm fusing film unit
94 mm, photosensitive drum
I hope this helps :c)
Thanks and please take a moment to rate as fixya.
  • Kevin Shafer
    Kevin Shafer Nov 06, 2008
    Defective toner cartridges as well as the drum can also cause this problem. If you would like, I can email you the service manual.
When using both the FAX and COPY functions of the Canon Laserclass 710 the printed page shows a 2nd "ghosted" image of the primary image about half way down the page. We've tried a few adjustments but the...
Generally, when you have a ghosting problem, the issue is with the fusing unit. If you have a new fusing unit (or if you can get one) install the new unit and the problem should go away.
If you don't have access to a new fuser, you can try replacing the drum/imaging unit. Sometimes a ghosting problem can be caused by a bad cleaning unit (inside the imaging unit), but usually it's the fuser causing the problem.
Aug 31, 2010 | Canon LaserCLASS Fax 710 Printer
Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
May 14, 2010 | Brother MFC-7820N Laser Printer
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
Printed page not clean, faded characters in background of page. Any suggestions? I cleaned the pickup roller.
Have you tried another toner cartridge? And when you say it has faded characters in the background? Does it look like it's reprinting the image kind of? If so, you will need the fuser unit replaced. The fuser is responsible for melting the toner to the paper, when it goes bad it can cause "ghosting" meaning it reprints previous images. A technician would be needed at this point, the part number for the fuser is RM1-1289.
Please let me know if there is anything else you need.
Aug 03, 2009 | HP LaserJet 1320 Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Printouts have type ghosting
Change the fuser unit if you have to hand. The problem is likely caused by a lack of pressure from the pressure roller. Also check the transfer roller for a similar ghost image.
Sep 14, 2008 | Samsung CLP-510 Laser Printer
I have the Phaser 6200 and ghosting images are starting to appear on everything. I would say that about one third of the top part of the page is being reprinted very faintly at the bottom of the page. ...
Most likely you need to replace the fuser. The teflon coating on the heat roll wears, when it does some of the ink sticks to the roller and winds up as a "ghost" image across the page.
It could be your imaging unit. But more likely is the fuser.
Let me know please.
Jul 23, 2008 | Xerox Office Equipment & Supplies
Getting extra characters printed on paper from previous run
Asside from removing the toner cartridge and using a lint-free cloth or tissue to remove toner residue (or possibly using a can of compressed air to blow it out) there isn't much to be done to clean it. If you are getting ghosted images from a prevous page, your toner cartridge may be defective.
If you are using a refurbished or re-manufactured toner cartridge this would not surprise me. The only remanufactured toner company my clients have had any success with is Rhinotek, but i recommend sticking with the HP cartridge. Also if it is an older cartridge and infreaquently used it may still need to be replaced. If replacing the toner doesn't fix the problem after several test prints, then it is possible that the fuser is bad... in which case it's time for a new printer since the fuser is not replaceable.
Jun 25, 2008 | HP LaserJet 1000 Printer
Light print over entire page
clean the scan unit reflector
Mar 15, 2008 | HP LaserJet 2300d Printer
Xerox DocuPrint P8 Laser Fuzzy Printing
Maybe a bad fuser . That would cause ghosting and reprint on the page
Feb 02, 2008 | Xerox DocuPrint P8 Laser Printer
HP LaserJet 2100 Printer Logo
333 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
