Question about Samsung TXJ2554 TV
No picture when TV is turned on, sound is OK
When the TV is turned on there is nothing on the screen. Sounds comes on OK after the normal 'warmup" time. This used to be an intermittent problem...if you waited 10 minutes the picture would come on all of a sudden. Some other tech references have suggested a bad flyback. Another user seems to have posted a similar problem for the same model. thx
  • 5 more comments
  • richard buan Nov 06, 2007
    i soldered all the loose joints of components... and change all cold solders
  • unc23pete Mar 01, 2008
    the set takes about 15:00 min. two warm up
  • sleepyweasel Mar 16, 2008
    My Samsung tv works well until I turn it off and turn it on shortly after I have sound but no picture. If i leave the tv off for about 1/2 an hour or more it will turn on with no problems any ideas??
  • olemram May 11, 2008
    I have the same problem to, got sound good but no picture, I try to test the flyback by pointing a screw driver on a pin that goes to the CRT and the arc that produced is just so thin do you think that ther's something wrong with the flyback?
  • Anonymous Jan 11, 2009
    i cant get any picture on my tv
  • axxxm_89 Nov 10, 2009
    what the problem television when no sound, no image but LED on??
  • enrique licon
    enrique licon Sep 10, 2014
    why is it to dark
    Sergeant:
  • 337 Answers
Lets try something ,turn the set on and put you forearm in the face of the picture tube if your hair stand to static it means you have high voltage and your set is missing possible the screen or filaments volts,if the hair in your arm does not stand your set is missing the high voltage and the problem is related to the flyback but it does not mean is bad ,it could have a loose conection in one of the legs or in the near area,next time it happens tap on the side of the set to see if it reacts if it does you know you have a loose conection.If you are familiar with tv service this will be a good place to start but if you are not too familiar be safe and call for assistance from a servicer.Let Us know if you need more information and how it goes.
Posted on Oct 13, 2006
  • Omar Urrutia
    Omar Urrutia Oct 13, 2006
    Your rating response is important too.
I have an LG plasma with no picture just sound
Posted on Jul 27, 2009
  • rajkamal_568
    rajkamal_568 Jan 03, 2012
    no picture eht ok
I have a toshiba sound great but it has grey back ground with white lines across
Posted on Dec 11, 2009
    Scholar:
  • 68 Answers
I have a Philips Matchine television which does a similar thing, the problem is in the receiver part of the set, where I have traced the Video signal with an Oscilloscope to a particular Chip (Integrated Circuit). By increasing the Contrast to maximum the picture can be brought back again, but still lacks contrast. The fault is varies as the chip warms up. Therefore you can locate the chip by cooling or heating it from a special non inflammable spray can. Have you tried the scart input which may work OK, then you can use the television as a monitor, as I do. Cost of repair is not worth it.
Posted on Oct 15, 2006
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
TV issue is not right
Posted on Sep 10, 2015
My swish on my tv will not work tv will not go on
Posted on Nov 14, 2010
    Problem Solver:
  • 6 Answers
My 26 in Samsung tv did this to me too! took me a long time to get it fixed (and $250 ) ,but i had my backup tv i got from here http://geo.tv-in-pc.com/?source=04017w5r86o3en6qzirpkewq3m
Posted on May 18, 2010
2 Suggested Answers
  • 12 Answers
SOURCE: No picture when TV is turned on, sound is OK
try to look at its circuit board and look for cold solder or loose solders usually solders with crack,they might be the problem,i dont think its the flyback coz you have audio.try also look at its picture tube at the back tru the crt if the filament is ok or it may also have loose connections
Posted on Jan 13, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
No picture, no menu, black screen, no raster, sound ok
From your detailed description, it sounds that the main chroma processor IC has damaged. Raster means nothing, but the lighted screen that appears, when a TV is switched ON. For some brands, there will be a blue screen; when there is no signal input, and some others will have a bright white screen with some snow.
I advice you to contact any service technician, to get this TV repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 07, 2014 | Televison & Video
Black screen only on new LCD
Sounds like the video board when bad. I would say the TV went defective. Use the 90 day warranty to exchange for a new one.
Always use warranty at this point because the newer TV coming out in these days have very lame warranty.
Rate me, please
Feb 02, 2009 | Televison & Video
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
Jan 13, 2009 | Samsung TXJ2554 TV
No picture yet i can hear sound green effect before it happend
First thing would be to make sure that you're only using the yellow, red, and white cables, but seeing as how you said you had picture before, I'm guessing that's not the problem. The 360 uses an automatic recognition for the hardware to make sure that it is set to the right input. So, in essence, it won't be that the settings were changed. I would say go pick up a new cable and see if that's the problem, it sounds like it is. If the cable doesn't solve it then I would say it's time to call Microsoft. For the guest with nothing working, call up Microsoft, I really don't know what else the problem could be except for hardware.
Oct 04, 2008 | Microsoft Xbox 360 Console
SHARP 37HV6U No picture until long warmup
Alas, it sounds like something could be quite wrong, or it could be as simple as needing a reset. Unplug the unit, wait a minute then replug it and see what happens.
Aug 28, 2008 | LG 42LC2D 42 in. LCD HDTV
Turning on TV after power outage
Not sure what you mean by "older", but I assume it's a CRT display. It takes some time for a picture tube to come up from a completely cold start. It has to get all of those electrons hot enough to start flying around, and also build up a high voltage on the screen. You don't notice it in normal operation because the power button doesn't really turn everything off, but just puts the set in standby mode. Unplugging, though, lets everything cool off completely.
If you're talking real antiques, with tube-type amplifiers, then the warmup time could be even longer. I remember as a kid watching the blank screen for a couple of minutes before a picture appeared.
What you describe sounds like normal behavior for a CRT television. Not sure what's up with that flickering red light, though.
Jun 26, 2008 | Televison & Video
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Samsung TXJ2554 TV Logo
17,277 people viewed this question
Jerry Greenberg
Jerry Greenberg
