Question about VeriFone (M19755014US1) Magnetic Card Reader
Printing we cannot print a receipt for the transaction. It just makes a noise.
Does it feed a length of paper? if so, you may have either the wrong paper, or the paper loaded incorrectly. It needs to be thermal paper, and it will only print on one side, so if you are sure its thermal paper then try turning the paper over and loading it that way.
If it doesnt feed any paper and just makes noise then the problem is probably a broken gear inside the printer. For this you would need to find a place that can repair these terminals.
Posted on Jan 07, 2009
XE-A207. Won't print while ringing up. But will when transaction over if you push receipt copy. It will print x/z readings
The receipt is turned off.
Turn key to OP/XZ mode. Press receipt button. Turn key back to REG mode.
May 13, 2017 | Retail Supplies
How do i the machine transaction non print payment
I am confused ! Do you want to make a transaction without the printer? If so just lift the paper cover and don't print receipt. Call me to clear up this problem. Frank 775-338=6634
Dec 21, 2014 | VeriFone VX510
Can you print a receipt from the previous business day?
Only if it hasn't "batched" yet.
You can press the "Reprint" button (second from right purple button) to reprint the last receipt. You can also print any receipt that hasn't batched yet (normally from the current business day) by entering the receipt number. You can guess the number if you don't know it. Number 1 is the first transaction of the day, number 2 is the next one, etc.
If for some reason your transactions from the previous business day didn't get sent as a batch to the processor successfully, you would be able to print receipts for them. Otherwise, contact your processing company, and they should be able to send you a copy of the receipt.
Jun 19, 2014 | VeriFone VX510
Casio PCR-T470 wont print transaction receipts
Did you upgrade your system? At any rate, download the new driver or reinstall the one you have It may fix your problem
Dec 26, 2009 | Office Equipment & Supplies
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Printing
after the tranz prints the first receipt do not press the func/enter button, but rather press the clear button on the upper right hand corner. It will not print the second receipt nor will it cancel the transaction.
Jul 18, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
VeriFone (M19755014US1) Magnetic Card Reader Logo
178 people viewed this question
Top VeriFone Televison & Video Experts
AliennoisE
Bosse Photos
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
