Question about Samsung Digimax 200 Digital Camera
Samsung digimax 200
Fresh batteries, no power
  • graydemile Jan 07, 2009
    i have tried four new packs of batteries and still no power
  • 56 Answers
Make sure that you use a battery with 2500MAH or 1.5v or more
preferably lithium instead of alkaline
Posted on Jul 02, 2009
Vivitar vivicam 6300 will not power on with fresh batteries
I think it is the problem not oriented with battery. Just make sure that your cam battery placing area have any rust. If so just try to clean the rust and re-insert the battery and check it off.
Jul 29, 2013 | Cameras
I have a freshly charged battery but still can't
The alternator could be draining the battery or the cables may not be connected right.
Jul 28, 2013 | Motorcycles
Have an olympus camedia c750 ultra zoom that will not stay on it beeps and closes with fresh batteries etc. it will some time turn on on its own and then close
You have an internal power input problem.This happens even with a new or fresh batteries.The internal power regulator is defective and needs to be replaced.This component is in between the battery and the circuit that powers up your camera.It will require service by a Digital camera service technician,because of the tools and test equipment required to diagnose it and repair the unit.
Jan 30, 2011 | Olympus Cameras
My sb will power on but i have no flash even when i hit the test button. I noticed it got a little warm then shut down when the problem first occured. Is it fried or fixable?
Are you using fresh batteries? Are they rechargeable batteries if so do a battery test maybe a battery is weak. With fresh batteries it still does the same thing then call Nikon 1-800-645-6689
Aug 28, 2010 | Nikon Speedlight SB-800 TTL Flash
Battery is charged, however there seems to be more power
Yes a charge fresh, fully charged battery will allow for the scooter to perform at it's peak top speed. Also fresh, fully charged battery will read more than 24v on a voltage meter and this is ok.
Aug 13, 2010 | Razor E100 Electric Scooter
Kodak easyshare C182 camera. It is six days old with fresh rechargable batteries inside. It will not turn on at all. HELP PLEASE :)
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
Contact KODAK:
Nov 04, 2009 | Kodak Easyshare C182 12MP Digital Camera
Will not power on
It should power on using internal memory. Your problem is normally due to weak/dead batteries. Make sure that you have fresh batteries, or freshly charged batteries, installed. If changing the batteries out does not eliminate the problem, the camera is a likely candidate for the repair shop.
Bill B.
San Antonio
May 12, 2009 | DigiLife DDV-C330 Digital Camera
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
Power wont stay on
Remove batteru for a minute and insert it again. There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2 (icon looks like a wrench with number 2 on it)
- Scroll down to Battery Type
Under Battery Type, there are two options:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
Nov 13, 2007 | Samsung Digimax S630 Digital Camera
Camera will not power on with fresh batteries
Do you see a red light when you press the power button or is there no activity at all?
Feb 23, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Samsung Digimax 200 Digital Camera Logo
29 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
