Question about Gateway Computers & Internet
I have a gateway computer. I took the side off and cleaned it out with air. Inoticed it had a CR2032 battery on a ckt board. we have had this computer for several years. should i replace it or check it. Should i have a power cord hooked up before i take the battery out. AL
  • 30 Answers
That is just the BIOS battery, they generally do not need to be replaced.  If they do eventually go dead, it will be noticable because your system will not be able to keep the correct time while it is powered off.  If you begin to notice that the system clock stops while the system is powered off, this is a good indication that you should replace the BIOS battery.
Posted on Nov 06, 2008
Low beams dont work and only one high beam works
Do you know how to do voltage drop testing ? Leave the blubs in there sockets turn the low beams on , measure voltage on the power side , LH low beam yellow with black stripe an for the RH low beam dark blue wire . If you have battery voltage there, power side is good . Then check ground side both are yellow wires , test with lights on . if you see 6 volts , 12 volts .anything more then .03 millivolts you have a ground side problem . The lights ground through the light switch .
Low Beam
Voltage to the headlamp switch is available at all times from the HDLP SW fuse 7 through CKT 1940 (ORN). When the headlamp switch is turned to the HDLP position, the headlamp power relay coil is energized through CKT 352 (WHT). A signal is also sent to the body control module (BCM) that the headlamp switch is ON. When the headlamp switch is in the AUTO or PARK position, the ambient light sensor (located in the right speaker grill) senses either daylight or darkness and sends the signal to the BCM. When the Ambient Light Sensor detects a dark condition, the BCM produces a signal that will energize the headlamp power relay through CKT 352. The relay coil is grounded through terminal F7 connector 2 of the underhood fuse block to CKT 350 (BLK) to G102. When the headlamp power relay is energized the relay supplies power to the LT HDLP and RT HDLP fuses. The RH low beam headlamp receives current through CKT 198 (DK BLU) from the RT HDLP fuse. The LH low beam headlamp receives current through CKT 712 (YEL/BLK) from the LT HDLP fuse. Both headlamp low beam bulbs are grounded by CKT 524 (PPL) through the underhood fuse block to the multifunction switch (low position) contacts through CKT 10 (YEL) to the headlamp grounding relay in the body relay block through the normally closed contacts to CKT 1850 (BLK) to G200.
Oct 14, 2015 | 1999 GMC Sonoma
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
Aug 30, 2014 | Acer Aspire Z5771-UR31P - All-in-one - 1 x...
CMOS Battery for Gateway DX4860-UB20P Desktop
I have only found one type of CMOS battery in desktop computers. You need something such as a Maxell CR2032 or a compatible item.
Aug 23, 2013 | Gateway Computers & Internet
Where is the CMOS battery on an acer aspire x1700 desk top computer
Most motherboards use a coin size 3 volt lithium battery type CR2032.
Ti help you.
Download the manual for your model computer from this WEB site.
http://www.manualowl.com/p/Acer%20Computers/Aspire-X1700/Manual/65650
Feb 03, 2013 | Acer Computers & Internet
Need to replace cmos battery in Gateway MP8708
Power down PC. Open the PC tower. Look at the motherboard and find the CMOS battery. Looks like the picture below. Make sure you touch some sort of metal area on the PC to ground yourself before touching the components. Use something thin to pop the old CMOS battery out. The CMOS batteries are usually universal. CR2032 is the usual type used. These can be found at a CVS or Walgreens. Once you have acquired the next battery, make sure the CR2032 is facing up and just press it in.
-Ben P.
Dec 31, 2012 | Gateway Computers & Internet
Battery
All PCs have a battery. A small round +3v CR2032 battery; which saves the BIOS information in the CMOS chip when the PC is disconnected from power.
Laptops have 2 (and sometimes 3 ! )
Aug 24, 2012 | Gateway SX2802-07 PC Desktop
Change the cmos battery in a gateway dx4300
Remove the case to see the CMOS battery, in most computers it will be a coin size 3 volt lithium battery type CR2032.
After installing a new battery go into the BIOS setting to set the Time and Date etc.
Mar 24, 2012 | Gateway DX4300-03 Desktop PC
I am using Maxell CR2032 in my computer having Gigabyte Motherboard Model Name: GA-GS31M-ES2L. The cell lasts only for 30 to 45 days.Normally celle/batteries lasts for years in computers. Kindly provide...
Hello sellagiri
You are right. These batteries should last years.
Your problem generally indicate faulty main board. there is a leakage that drains the battery.
Check the assembly of the computer. Make sure the main board is properly assembled and soldering and joints are not in contact with the case, there is no wires from the case touching the battery or its contacts, remove the battery and clean its housing.
Other than these it usually means faulty board.
Good luck and thank you for using Fixya
May 17, 2011 | Maxell CR2032 3V Micro Lithium Cell...
Whenever i start my computer i find my time to be 12:00 1st jan 2002 how can i set it
Hello Saifthesmart51, Hi looks like you need a replacement battery for your motherboard, after replacement, set the time in bios or in windows. The battery looks like this. CR2032 cyberdyers_4.jpg
Feb 09, 2011 | Computers & Internet
Spilled onto Acer Aspire laptop
I suggest you download for $6 the service manual for your laptop here
http://www.9manuals.com/gateway_sm.htm
You take it appart and clean everything electronic board component side and wired side with alcool (not beer, something like 90%), you wash the plastics, and build everything back together.
Before pushing the power button, pray a little bit ;)
20mn was too short anyway , next time it's two days min. by hot days.
Good luck and don't forget to vote,
cheers
Jan 03, 2009 | Gateway CX2608 Notebook
Computers & Internet Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
