WOULD YOU PLEASE TELL ME HOW TO TAPE PROGRAMS (THIS IF FOR TONIGHT) FROM MY TV ONTO MY OLD VCR MACHINE. THE TV IS SONY, THE VCR IS TOSHIBA. I WOULD SO MUCH APPRECIATE YOUR HELP! THANK YOU
  • 1 more comment
  • toodle264 Nov 06, 2008
    So, here is the model number of the TV, as you requested:
    SONY TV-TRINITRON- MODEL NO. KV-1926RA
    (difficult to read, may have been KU)
    *****THERE ARE NO RED, YELLOW OR WHITE THINGIES AT THE BACK OF THIS TV.
    THEY EXIST ONLY AT THE BACK OF MY DVD PLAYER.
    It looks like that was it! Am i going to receive further instructions? You asked for the model no. which i have given/
    and i've stated that i have no red, white or red attachements at the back of tv.
    And so, what is next?
    thank you!
    ****How can i RATE this solution, when you have not kept up your end?
    I gave you the info you asked for......told you about the absence of red,white,yellow chords.......and i have received nothing back from you.
    I am needing to tape something for this evening, paid the required amount for your aid, and you have stopped our communication.
    Anyone out there?
    thankyou,
    linda
  • 849 Answers
Get audio and video output (a av cable is needed) from tv and put them to vcr and pressrecord button. it will start recording.
Posted on Nov 10, 2008
    Genius:
  • 1,605 Answers
If you have cable:
connect the income cable to the input on the VCR. the VCR output connected to the TV input.
Set the date and time on the VCR. and set the propram to be record.
if you don't have cable. antenna connection goes to the input of the VCR. the outpout from VCR is connected to the TV input.
this is the basic setup. if your VCR is different or don't have the cable connector then e-mail me at frcs68@hotmail.com
Posted on Nov 06, 2008
  • 2,326 Answers
Can you please provide the model number of your TV?
If you check the back of your TV, you should see a number of connectors yellow, red and white. Find the one that says AV output, that will be the connection to use to connect to the VCR AV input. Select the VCR to the appropriate AV input to record programs.
  • Jaime Hernandez Nov 06, 2008
    If your TV does not have the yellow, red and white connectors, then you will need to connect it as follows: antenna/cable connection goes to the RF input of the VCR. the RF output from VCR is connected to the TV input and the TV should be tune to channel 3 or 4 and the VCR to the channel you want to record the program from if you do not have a satellite or cable TV converter. If you have a cable converter ot satellite receiver then both the VCR and TV should be tune to channel 3 or 4.
    Click here for additional hook up diagrams.
    Master:
  • 505 Answers
1. Turn on the VCR and then the TV, and change the TV channel to 4.
2. Insert a videotape. The VCR should be on already.
3. Set the "TV / Cable / VCR" switch on your remote to "VCR," then:
On your remote, type in the channel that your program is on.
This changes the channel in the VCR, not the TV (which must remain on 4.)
4. Press the "TV / Video" button on the remote. You should now see the channel your program is on. (The VCR should always stay in "TV" mode.)
5. Optional: Set the recording speed to "SP" (fastest) or "EP" (slowest) by pressing the "SP/EP" button on the remote. You may also want to reset the elapsed time clock by pressing the "C. Reset" button.
6. Press the "Rec" and "Play" buttons simultaneously. The word "Record" should appear on your TV screen for a few seconds, and your VCR should light up "REC" in red.
7. When you're finished press "Stop."
Thanks
  • Indrajit Roy
    Indrajit Roy Nov 06, 2008
    How to set your VCR to record overnight
    Press the "Menu" button. If you don't see a menu, try pressing the "TV/Video" button. The VCR should always be in "TV" mode.
    4. Press the "Select" button. This will access the "Program Set" function.
    5. Press "Select" again. This will select the first area to save your timing information.
    6. Input the date, start time, stop time, TV channel number, and tape speed. To move between the different fields, press the "select" button. To change a setting, press the CH/SET "+" or "-" button. If you miss a field, press "select" repeatedly until you return to the field you want. (Except for the channel number, the keypad on your remote will not work.) If the word "error" flashes, this means you have currently set the timer to record at a time which has already passed.
    Note: the day of the week will appear automatically. It may be incorrect, but just ignore it - the month and day are what is important.
    7. Press the "Menu" button. This will save your settings.
    8. Press the "Menu" button again. This will set the Auto Timer to "ON" and return you to regular viewing. (To move between the two choices, press the "+CH/SET-" button.)
    9. Power off your VCR. After a short pause, the VCR will light up the word "Timer" in yellow and turn off. Make sure your VCR is OFF when you leave the building, otherwise the timer will not engage. (The VCR displays only the time of day when it is off.)
    That's all!
    Tip: In the morning, press the "REVIEW" button to automatically rewind to the beginning of the recording and start to play back.
    Having problems?
    We'll be happy to help you to walk you through this process.
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
Setting up used VCR
did you check the channel select swith on the toshiba?
Sep 06, 2009 | Toshiba W612 VCR
I have a Sony SLV-SE 710B VCR and a Sony Bravia HD TV I now wish to record my videos (about a 100) onto DVD. What Sony DVD recorder will take the output from this VCR and put it onto disc or do I have to...
You need to buy Sony DVD Recorder and hook Sony VCR to that dvd recorder and burn DVD directly. You can also watch VCR tape movie on TV via dvd recorder while its being burn on dvd.
Click Sony Style to select DVD recorder.
May 11, 2009 | Televison & Video
Taping digital onto a vcr
You'll need to connect the VCR to the converter box and then connect your VCR to the TV. ou can get a diagram showing how to connect everthing at www.dtv.gov; there is a section with publications that has a document on how to hook up your VCR to tape the show your watching or watch one show while taping another.
Mar 14, 2009 | Insignia Digital-to-Analog Converter for...
Can the Magnavox Dvd player/VCP DV200MW8 record shows onto VHS's
unfortunately the machine is not a recording machine IE: it is a player only. However in todays day and age you can pick up a good used one at the goodwill for around 10-20 bucks that can record. hook up is easy, one cable in one out and presto you can record on a blank tape. just remember the begining of a blank tape always has a few seconds of nothing on it so dont hit rec just as you are watching it start the machine about ten seconds early.
hope this was helpfull.
Dec 27, 2008 | Philips Magnavox DVD/VCR Dual Player
DVP3345V/17 can't watch TV Programs
I would like a insturction book, as I never receiver one. I can't fine the channel on the vcr to match the channel on the tv. to tape. My Name Carol King
Address 229 Billings Ave.
Paulsboro., Nj. 08066 Thanking you
Carol King
Model #DVP3345v/17
Serial #SG1A0816014102 Make Philips VCR/DVD
Aug 16, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a VCR
here is a link for the wiring diagram for direct tv to VCR:
http://directv.com/learn/PDF/Wiring_Diagram/RCA/pg11.pdf
I am working on your codes:
Dec 09, 2007 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
