Question about Toshiba MV20FL3 Combo
Programming I've lost the user manual. How to I turn on timer recording light? I entered a program to record, but the light does not come on.
    Sergeant:
  • 337 Answers
Try pressing REC and TIMER at the same time.
Posted on Oct 13, 2006
  • Omar Urrutia
    Omar Urrutia Oct 13, 2006
    Your rating response is also important.
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
May 16, 2013 | Emerson New Original VCR4010A Remote...
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I can't find my manual. I need to hook it up so that I can record tv shows I like to watch when I am not home. But I didn't do it right and I am having trouble with the remote also.
You can download a manual from http://www.funai-corp.com/support/manuals.aspx . Click on Customer Support and then Owner's Manual. Remote problems - first try new batteries then try a universal or other replacement remote, http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWD2203+&uuid=12828737757670 .
For problems with timed recording, make sure the clock is correctly set. If power goes out for more than 30 seconds, the clock will be incorrect and the timer information will be off. Insert a blank tape (or one you want to record over). Then press Menu and then go to Timer Programming. (Use the up/down arrows and then hit the right arrow button.) Set the frequency of recording followed by the day and start time of the programmed recording. Then set the end time of the recording. Next set the channel number. (with some set top boxes and TV connections, choose 3 or 4 depending on the way the setting of the RF output. Then set the channel on the set top box and leave the box on.) Then set the recording speed. Press T-set to lock in the program. If you want to watch a tape before the program starts, press T-set (turning off the timer light). Remember to press T-set afterwards to resume programmed recording. You can't record to DVDs.
I hope this helps.
Aug 27, 2010 | Emerson EWD2203 DVD Player/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Timer Recording
This is from the KR10 manual. Hope it helps.
1. Set the clock before setting a timer.
2. Insert a recordable disc with enough space.
Then:
1. Press [TIMER PROG] on the remote
2. Use up/down arrows to select "New Program" then press [ENTER]
3.Use up/down arrows to enter the date, then press right arrow
4. Use the arrow keys to enter the start and end time, then press right arrow key.
5. Use the up/down arrows to select the external input position to which your cable/satellite box is connected, then press [right arrow]
6. Use the up/down arrows to select a recording mode.
7. Press [ENTER] when all items are entered.
8. Press red [I/O ON STANDBY] to set a timer programming.
DO NOT FORGET THIS LAST STEP! The timers will not work if the recorder is not in standby mode.
Jul 24, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Record
i have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
menu
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
trin
Nov 16, 2007 | Sylvania SRD3900 DVD Player/VCR
Toshiba MV20FL3 Combo Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
