Question about Toshiba Satellite A135-S2276 Notebook
Toshiba Satelite 235 will not play or burn CD's or DVD's.
Drive stopped working after 1 year. Laptop does not recognize any disc. Drive is visable. Shows working OK. Inserting any disc causes the drive to run endlessly with no response from the computer. Running Vista Premium. No error messages.
  • grpgui998 Nov 06, 2008
    I turned off the acoustic drive silencer for the DVD/CD drive and everything works fine.
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
Posted on Nov 06, 2008
    Genius:
  • 1,550 Answers
You need to clean the lens .
Buy lens cleaner to clean the lens .
  • 1,879 Answers
Try a CD lens cleaner
CD/DVD Drives work on a generic or system driver, so all about the physical condition of the lens.
  • monk3ybidzness
    monk3ybidzness Nov 16, 2008
    Nice info. So it's all about the extra feature that the manufacturer integrated with the CD/DVD drive.
What type of DVD should I use to record or burn a movie on it in my Toshiba Satelite A100 lap-top computer?
Go to www.ebay.com Type: Make and Model of your laptop and refine search DVD driver, you will be presented with a choice of DVD units at different prices, stay away from the used drivers, "they are a gamble" But you need a DVD/R-WRITER to burn discs and watch movies.
Apr 10, 2012 | Toshiba Satellite A100 DVD/CD-RW Combo...
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Dvd rom not reading cds/dvds
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
Mar 21, 2009 | Compaq Presario C700T Notebook
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Laptop CD/DVD Drive
Hi RC2935
Try this and see if it will help you
Here is what you do  Click on start and then go to run type in regedt32 For Vista Click start and search for regedt32 and click on it
Go to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the upper and lower Filter or witch is available close window and restart the PC it will work
This is common on the Acer, HP,Toshiba etc,etc
if you need help let me know
kind regards mervin
Sep 24, 2008 | Computers & Internet
CD ROM PROBLEMS?
the 1800 series probly doesn't recognize cd-r discs. The composite out requires a driver which may not be loaded.
Good luck
Nov 22, 2007 | Toshiba Satellite 1805-S204 Notebook
Dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Sep 16, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba Satellite A135-S2276 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
