Question about Toshiba 57H81 57" Rear Projection Television
Parts for 57H81
I need fuses and IC's for the the 57H81. Where is the best place to get them and who has the best price?
  • Fred Macciocchi Oct 14, 2006
    This post was answered in another post.
    Thanks,
    C5Z06
  • Fred Macciocchi Jan 20, 2007
    Close this thread. Solved in another.
Tritronics in florida
Posted on Aug 21, 2007
Have toshiba 2002 projection tv model 57h81 when plug in red light on front where power button is the tv has no sound and no picture please tell me what it means or is too expensive to fix not worth it...
9f2965aa-94e3-4244-a87e-5f0264d7f11c.jpgthe price of the parts depend on the problem I have done a problem part list on to this picture hope this help most of the parts if you type them into ebay the parts will come up check them to the one on the board. sorry had to change the size of the picture as it has to be under 500k. switches are in the red ring if they don't click when you try to turn on or just keep clicking then i would check them. you should be able to download the picture and enlarge the picture so you can see the problem areas i have put on it hope this helps there is a bit of soldering to do to replace them if you need more help please reply.
Oct 21, 2013 | Toshiba 57H81 57" Rear Projection...
People seem to have an aura
the problem on your tv is the convergence ic , this parts need to be replace is not an easy fix , you need to hire a tv tech normal cost about $200
Sep 12, 2012 | Toshiba 57H81 57" Rear Projection...
I have convergence on all colors except blue on my Toshiba 57H81, Which parts do i need and where is the best place to order them from? Thank you in advance, Bob
U have all the tools like a soldering iron,a desoldering pump or a roll of desoldering braid and pretty good at doing soldering work,because were talking about ICS here?Must take out the covergence board to replaced 2 convergence ICS and some or all of it resitors.The websites like Tvrepairworld.com,Tvrepairkits.com have a convergence kits,just look for ur DLP tvs make and models for ur convergence kits.Or the shop,will cost u like $300-350 for parts and labors.
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
Lens positioning, blurriness
need replace convergence ic chips to resolve this issue, parts cost about $40
Dec 19, 2010 | Toshiba 57H81 57" Rear Projection...
Location of convergence chips in Toshiba 57H81.
hello if you can use a soldering iron you shouldn't have any problems but you will need to test the resistor in front of the ic and the capacitors at either end of the ic ! the ic usually located to the right hand side of the tv behind the tuner board connected to metal frame called a heatsink 2 big black chip good luck
regards
shaun
Mar 27, 2010 | Toshiba 57H81 57" Rear Projection...
I need an IC Part for the TV. Are these expensive parts and is it a difficult repair job ??
I asume you're talking about convergence IC's? The IC's themselves are about $50.00 total
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 25, 2009 | Toshiba 57H81 57" Rear Projection...
Screen turns green
Ur video ic inverter board is dead or have shorted parts.U need a new board.
Aug 19, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba big screen
yes. I did get my Toshiba 57H81 Fixed. But the remote control doesn't work afterward. I have to pull the mainboard out again to see if there is any problem during the IC replacment.
Sep 13, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81
Check all fuses in the power supply and look for any bad connrctions on the PCB. You are probably missing the 130 volt supply to the horizontal circuit. Common reasons are: Shorted horiz output transistor; flyback transformer, picture tube arcing , bad power regulator IC. In short, you need to get a qualified tech for this symptom. Hope this helps.
Oct 29, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 Blinking power light
This sounds like the typical toshiba power regulator ic fault. it begins with an str##### Its not something a handyman should try to tackle. It should be repaired by a quilified repair person Sorry Good Luck
May 22, 2006 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
