Question about Electronics - Others
Wiring motion sensor light
I have a motion sensor light that I have no instruction manual. The light has three wires running out of the sensor. Black, red and white. The bulb has only two wires running from it. The way I have it wired right now, with all the blacks and whites connected to each other makes the light go on but the sensor won't turn it off. I do not have the red wire connected to anything.
I have also tried the black from house to black from sensor. The red from sensor to the black for the bulb, the the white from the bulb, white from sensor and white from the house all connected. This doesn't turn on the fixture. Can anyone help?
  • Les Aberle
    Les Aberle Nov 13, 2008
    Bulb o.k No amufacturer shown on the light. Tried your suggested hookup. I think my wire connector shorted out the sensor when my wire nut on my red wire came loose and shorted against the bulb chassis. Think it fried the sensor so I got a new light. Bulb still works so maybe I can use it in a place where a sensor isn't important. Thanks for your help.
    Scholar:
  • 157 Answers
Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
Posted on Nov 12, 2008
  • Gene Pitts Nov 13, 2008
    Your sensor can be replaced byitself, less cost than a whole new system. I thank you for the reply.
What do I do with the red wire on a Brinks Halogen Motion Sensing outdoor security light
Please perform these connections with the mains power off.
The standard is the Black wire is hot, the White wire is neutral, and the Red wire is switched. For your Sensor connection 120V is connected Black to Black and white to white while the Load is connected White to White and Black to Red (assuming your load is using standard color coding.
Here is a simple diagram for your connection.
Mar 01, 2015 | Electrical Supplies
My flood lights have a manual function so that I can wire a light switch to them and use them with switch as well as a motion detector. However the users manual does not provide instructions or diagra
you need to either break the circuit going to the light, so find the wire that powers the light & cut it where you want the switch, then join the black wires together & put the reds in each end of the switch.
or the way you asked about, which will depend on what your light has in the of terminals in the conection box.
ill do you a drawing..........
flood-lights-manual-function-wire-light-kh0zpbanw2f22f2jnqn4pytl-4-0.jpg so take the red out of its terminal in the back of the light, put it in its own conector or a spare one thats already in the light, might be labeled (manual function) then run one 2 core/ twin & earth wire to where you want your switch to be, & then wire it up like the picture, red in com black in either l1 or l2..
go back to the light & take the red of your new wire & put it in the same terminal as the one i just told you to take out, then put the black from your new wire & put it where the red wire was to start with.
your live could be either red or brown depends on the cable used.
check your swith aswell b4 screwing it to the back box, to make sure you put it the right way up,nothing more anoying than an upside down switch.......lol
good luck!
Sep 26, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
Oct 17, 2012 | Hardware & Accessories
Own a Heath zenith sh 5105 motion detector flood light. I wired it to plug into an outlet. Flood light comes on when I plug it in and stays on. Seems as if the sensor isn't working. Do I have it wired...
look to see how you have it wired, most sensor lights have many wires to put together, if it is not wired already from factory, you need to look to see how you have it wired, most sensors have three wires one black one red and one white, black wire goes to power, red wire goes to lamp, white goes to neutral, after all is wired you should have only 3 wires a black a white and a green, black to power white to home neutral and green to ground
Oct 31, 2011 | Home
I have a cooper 6107 motion sensing 3 way wall swithch and I am using it to replace a three way non motion sensing switch. I have it wired correctly, green to ground, black to common, and the red and brown...
Cooper 6107 instruction sheets:
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/instruction_sheets/469mt_pta_rev._a_.pdf
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/spec_sheets/std_sensswitch_spsht_4_10_anp.pdf
3-way installation shows two motion sensor switches.
Instructions do not show 1 motion sensor and 1 ordinary 3-way switch.
Also note the maximum load rating is 500Watt
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical work or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 09, 2011 | Cooper Wiring Devices Motion Sensing...
I installed the motion sensor on a 3way switch. Connected the red lead to the common and the yellow w/red strip lead to a traveler and the black lead to the other traveler. No matter how i switch the...
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Nov 23, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
How do myou connect a 110 motion light
The motion light comes from the store with a neutral (white) hot (black) wires. If there are multiple light bulb sockets on the motion light, the black wires will be connected together and the white wires will be connected together. There will be a motion sensor that has a red, white and black wire. The red wire is connected to the black wires from the bulb sockets. The remaining white and black wire from the sensor switch are connected to the line power from the panel. you must remember that all white wires from the entire project are to be connected together.
Most motion lights feed the line power from an independent switch that connects the power to the motion light fixture. Remember never to connect the white conductors to any red or black wires, as this will create a ground and you will continue to trip your circuit.
I hope this has been helpful.
Aug 15, 2010 | Home
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
Electronics - Others Logo
248 people viewed this question
Top Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you an Electronics - Other Expert? Answer questions, earn points and help others
