I went to Foxconn site and I chosed right socket and model, but it only says something like: "your request returned no results". My friend lives in Russia, and I live in Sweden. I have some Kingston DDR2 533 MHz modules 2x512 MB and I want to send them to him, but it is possible that they will not fit. Like it happened with my old buggy ASUS motherboard. Exact RAM model is - KVR533D2N4K2/1G (1GB PC2-4200 CL4 240-Pin DIMM Kit (2 pcs.)) Do you think those RAM modules will fit to that motherboard ? Or he should search fo some other ones ? But the global problem is that it is impossible to get QVL for this motherboard.
SOURCE: Asus A7V8X 1 gb sim
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
SOURCE: 2 GB or more RAM is not functional
Hi Slavomir9,
I had exactly the same problem. I have the same mobo and tried upgrading to 2GB of exactly the
same Corsair memory and had the same problems as you. I persuaded the memory supplier to take
the Corsair memory. back. The then installed 2 x 1GB of Kingston RAM and it worked fine. I don't
think Corsair memory works very well with this card.
Peter
SOURCE: upgrade to 1g RAM
take your old ram with you when you buy the new one, also you new to know if you new duel channal memory
or parity memory
or edo or non edo ram
most of the information will be provided by the vender of the computer. hp tell you everything it is , duel channel, edo, non edo, parity and non parity memory than take the information you have on hand to fry electonics store or online to egg head.
pay alot less for the same memory they were going to charge you and arm and leg for..
rod is the candymangandy
SOURCE: Hi I have a pc and I would like to improve RAM.
They both are compatible with the motherboard although the Kingston Value Ram is the cheaper.
Regards.
Testimonial: "thank you it was a real solution"
SOURCE: I know that the motherboard
Hello
I would put 2 1 gig sticks in.2X 1 gb is 2 gig in one stick.
I know the specs., but I need Qualified Vendor List for RAM with guarantied RAM compatibility list - by my experience, RAM modules, that has specified with motherboard characteristics, do not always works with that motherboard. I need QVL.
SOLVED:
according tohttp://www.ramshopping.com/ where they sell Kingston RAM,
this motherboard is not compatible with any Kingston RAM modules. Pitty.
But, if somebody succeeded to use that modules with this motherboard -
post here about your experience, may be that MB is just not listed on Kingston
site as compatible, but I still have a hope that it works, but a small hope ))
Motherboard manufacturers cannot test every stick of ram available for each board. I have used Kingston Ram with Foxconn boards and have never found a compatibility problem. The fact that the website comes up with no results, would seem to indicate that there are no compatibility problems with this ram. The good thing about Kingston is the warranty. I have found my mobo the same as yours and kingston ram works fine. I have a buyer for it already!
very interesting =)
ok, I will not risc, by sending those modules to Russia, moreover, that
the guy found same modules quite cheap and he is going to test them, I wish him a luck. Actually he will buy 1GB module from Kingston to reuse existing one from Hyundai, so 2 slots for DD2 533 MHz will be in use. But thank you.
