Question about Minolta DiALTA Di250 All-In-One Laser Printer
What is error code C0650 mean
  • ERICGROESSER Nov 06, 2008
    What does error code C0650 mean
    Problem Solver:
  • 7 Answers
C0650: Faulty PC12 C0651: Faulty PC13
Relevant Electrical Parts Scanner Home Position Sensor 1 PC12 Scanner Home Position Sensor 2 PC13 Scanner Motor M5 Master Board PWB-A BCR Board BCR HGB Board HGB MFB Board UN2
Posted on Dec 28, 2008
  • Abdullah Rajput
    Abdullah Rajput Sep 18, 2012
    in my di520 there is a code shown in copier screen C0650, tell me what can i do . please
C1300 error code Minolta Di250F
Print Head failure. The print head is what has the copier LASER inside of it. Check the connection between the print head and Master board. Replace the print head fist then board, if you can find either one. The Di250F is a legacy Minolta machine now konicaminolta.
Jan 07, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Error code c1038 di250
Check all connections between the two main circuit board remove each connector and check for a bend pin if not replace both boards if you can find them di 250 is a legacy machine of Minolta now Konica Minolta
Sep 13, 2012 | Minolta DiALTA Di250 All-In-One Laser...
Error code c 1300 How can I fix this????
The c1300 error means that the Laser Printer needs a new Laser Unit. Unfortunately, it will have to be serviced/replaced.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Minolta DiALTA Di250 All-In-One Laser...
Code 0510
This is a Fuser Temperature error, You will need to have the printer serviced by a qualified technician or have the fuser unit replaced.
Aug 05, 2009 | Minolta DiALTA Di250 All-In-One Laser...
We need the chapter 14 of the manual for minolta dialta di250
Have you tried the Konica/Minolta website? They may have the manual in PDF format that will give you the needed chapter. Good luck.
Aug 04, 2009 | Minolta DiALTA Di250 All-In-One Laser...
C1300 error code
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and communications. For remedial actions, change the board, check for cable connections, and turn the Power Switch OFF and ON. (6) C10]] to C13]] C1300 1. Reset the malfunction and turn OFF and ON the Power Switch. 2. If the same malfunction persists, check the harnesses and PJs between PH Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
Dec 27, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Minolta dialta trouble code c0650
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
Oct 23, 2008 | Office Equipment & Supplies
Hi!
TRY THIS
access service mode .by depressing STOP- 00 --STOP- 0 -1
and than select counter, select trouble count and scroll untel you see what that cod means .
get back to me if you need more help
Oct 15, 2008 | Office Equipment & Supplies
Error Code C0500
Check the Fuser Unit - the part that heats up and melts the toner to the paper.
clean the contacts for the fuser lamp first.
Oct 13, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Minolta DiALTA Di250 All-In-One Laser Printer Logo
547 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
