Question about NewCon Optik BN-5 Binocular
Newcon Optik Night Vision Binoculars BN5
Any one help me to disassemble this Binoculars?
    Problem Solver:
  • 15 Answers
The lenses screw out, the electronics are in the body and this involves removing all the screws, including the ones behing the rubber casing. Why do you wish to strip them out?
Posted on Nov 29, 2008
We have BN 5 Night Vision, but it's not in working condition means after putting batteries too it does not work. please let me know hw the problm can solve.
Hello, make sure that the batteries are installed in the correct order. Also, check the battery contacts in the battery compartment and make sure that they are really clean. GB...stewbison
Sep 06, 2011 | NewCon Optik BN-5 Binocular
I have a newcon-optik stargate that will only come on about 1 second after I press the lever. It only worked about a week after I bought it although I can't send it for repair under warranty right away...
Hello, it could a bad switch. Have you tryed hold down on the switch and see that works. If so, then the switch is faulty. You know that this NewCon Optik CON STARGATE-M is Russian manufactured by Optik one of the six or seven Russian companies manufacturing these NV devises. GB...stewbison
Aug 31, 2011 | NewCon Optik CON STARGATE-M
Where to access the battery compartment to replace batteries on Tasco NV 356
It could be on the top with a small hatch door that holds two AA batteries. Also, there could be a screw in cap on the back that could hold one or two CR123A 3 volt batties.
Unless it has finger crip lever on the top, this piezo electric plunger. The plunger needs to be activated about twenty plus times to build some current for the storage capacitors that will charge a small batteries. stewbison
Jul 10, 2011 | NewCon Optik con Tasco NV-356 1st...
Was wondering if there was anyway to take the lens off my Newcon BN356/BN456 Binoculars to clean them?
Yes, First, when you take the lens off you binocular make sure you are in a very clean room.
All you have to do is unscrew them. Use a good lens clean that is anti-static. If you don't every piece of lent, dusty bugs, flaky shin, etc. will be attached to those lens. stewbison
Mar 31, 2011 | NewCon Optik BN-5 Binocular
My yukon20041 infored light has stoped working could it be the bulb can it be changed etc
Yes, some time the IR illuminate is encased in a small tube. Just unscrew the cover on the IR and see if you can remove it from the. Also sometime IR illuminator is in the back with a couple screws holding it in place. I will also tell it could get to be complicated. Just take you time and you will succeed in your endeavors. GB...stewbison
Jan 24, 2011 | NewCon Optik Optics
Little black and white dots inside the lens
It's not a problem with your NV monocular. These spots will occur on any image intensifier tube. EXAMPLE: Military standard states that if more than one black spot appears on the tube, then this image tube is rejected for use by the US Military Now like you NewCon Optik DN 140M it manufactured in Russia and they quality control doesn't even match the US Military Standards. On scale 1 to 10; US Military rating for the image tube would be 10+ while the Russian maybe 2+ and I said maybe. Another thing to remember here is that no two image intensifier tubes are the same. It just like finger prints on people not two are the same. It normally. stewbison
Dec 05, 2010 | NewCon Optik DN 140 M
I can't figure out how to dismantle the eyepieces on a pair of 10x80 WW2 German luftwaffe binoculars to get at the lenses
there should be a beveled lock ring on the eyepiece.look at it closely...there should be numbers or letters on it...now turn the eyepiece in half way....hold the eyepiece with one hand and wrap a piece of rubber cord around the the bottom of the eyepiece that has the numers or letters on it and twist ,,,it should come apart...the eyepice is actually two pieces the problem is sometimes you will have to apply a little heat to break the seal do not use pliers or it will damage them ..if i can talk you through it i will.. give me a call at 5088330650......www.reichinstruments.com
Aug 03, 2008 | NewCon Optik BN-5 Binocular
Night vision
go to google then click on shopping it is the best way to get items hope this helps.
Feb 21, 2008 | NewCon Optik NZT 22 Goggles
Tasco nv 356 night binoculars
Check the HV to the tube and see if you can see any discolouration or spots on the tube - they often indicate tube failure. Many binoculars use the one power supply for both tubes as the current demand is very low. Often, one tube operation indicates tube failure, but a wire or connection could be at fault.
Nov 27, 2007 | NewCon Optik BN-5 Binocular
Newcon BN5 bipppppppppp
Try contacting these guys, i cant find any online info about this fault, it sounds like a serious problem in the circuitry that can be fixed - the biiiippp is an error message and the shutdown should protect from further damage; http://www.newcon-optik.com/contact_us.html Hope this helps :)
Mar 31, 2007 | NewCon Optik BN 5 (2.5x62) Binocular
NewCon Optik BN-5 Binocular Logo
456 people viewed this question
Top NewCon Optik Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a NewCon Optik Optic Expert? Answer questions, earn points and help others
