I have a ge quietpower 3 dishwasher, there is standing water in the bottom that won't drain. There isn't any food clogging the bottom or anything so I am stumped.
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
SOURCE: Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
SOURCE: GE Adora QuietPower II Replacement Rack Wheels?
I HAVE A GE ADORA QUIETPOWER II. WHEN THE DOOR IS CLOSED THE BEEP IS SOUNDED INDICATIN THAT THE DOOR IS CLOSED BUT WHEN I PUSH THE START RESET BUTTON NOTHING HAPPENS. PLEASE HELP
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at www.allbrandonline.com
Hope this helps!
www.appliancepartsonline.net
I run the dishwasher and at the end of the wash there is standing water in the bottom of it.
We have the same problem. Trying to find something that we can unscrew so that we can get at what must be the stuff that's blocking the water from draining. Can't figure it out.
same thing
