Bryant Toyo Carrier Air Con unit Model 3 showing faults 001 003 105 will cool but not heat
  • 8 more comments
  • allanphillip Nov 06, 2008
    I feel this problem is due to a sensor problem on the indoor unit, the outdoor unit is fonctioning properly. NB: this is an industrial installation. On arrival at site the indoor unit was found to be ice logged.After defrosting the unit will still not due a pre heat before going in to heating mode.
    need to know what the faults are for 001 003 105 !
    mohamed 307, are you replying to a TV problem or my Air Con problem.
    Anyone know where I can buy spares for Bryant Carrier air con?
    Thanks but I knew all that! I need to know what the fault numbers represent. The unit works perfectly well but will not go into heating mode! Thanks again.
    Cation 007, thank you, I am in UK and can't as yet find an English branch!
    Cation007, many thanks will try it to-morrow. 18.54 pm here.Alan.
    lectec 1, sorry mate you have got it wrong! there is no igniter or air filter, the heating is created by a three way valve and the evaporater behaves like a condenser.
    Cation 007, thanks mate, you were the most help I can now contact Carriernow I have your information.Am now closing this site, Thank you.
    cation 007 was most helpful!
    Sergeant:
    Champion:
  • 435 Answers
I am not sure where you are from.
If you are in Australia,
You can get spares from here
http://www.carrieraircon.com.au/content.cfm?content=97
If in USA,
http://www.residential.carrier.com/dealers/authorized.shtml
Enter your ZIP code to find the dealer. They can get u the authentic parts you are looking for.
Posted on Nov 06, 2008
  • 1 more comment
  • Karthik P Nov 06, 2008
    Alright.
    Here is the link then....
    http://www.uk.carrier.com/Contacts/Spare...
    You can call them at 0870 600 1155
    and let them know what exactly you want ...
    Thanks.
    Could you please change the rating if this worked for you?
    Many thanks,
    Scholar:
  • 44 Answers
The voltage to the contactor could be low, a wiring connection(s) could be loose. There might be a high pressure, low pressure swith bad. The problem could also be the t-stat, defrost board, or the circuit board in the unit. You are going to have to try and determine what the problem is. There is not one thing that could be wrong, and it will require some searching and maybe some luck.
  • 905 Answers
You can try cleaning the sensors but if that don't work then they will need replaced
  • 1 more comment
  • jason Nov 06, 2008
    a dirty air filter can cause problems also, but the ignitor may be faulty , they will need to check it out to find out the exact problem
    thought this was a 310 model
    little confusing when its under a projection tv and no full model # , or is that the #? (3)
    President:
  • 1,952 Answers
Please make ur doubt and problem in brief
    Genius:
  • 1,550 Answers
There is some sort of circuit breaker .
Overload power supply has had tripped the circuit breaker.
You need to check it .
    Master:
  • 505 Answers
Its time to get the heat pump for your air conditioner to get repaired or replaced. Please click on the link below which answer about heat pump replacement.
http://www.hrac.ca/pages/consumerinfo/MatchedSystems.pdf
Thanks
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
Aug 30, 2017 | Bryant Heating & Cooling
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
I have a Bryant heating/cooling w/ heat pump - E3 error on thermostat and the house is 61 degrees and smells of burnt air
I asked Mr. Google " carrier e3 error code", and I found this.
The outdoor thermostat is in error, not connected, or shorted out. This code is displayed only if auxiliary heat and/or cool lockout feature is enabled.
What this means is that your o.d. unit has a component failure. The smeel you have inside is probably you electric heat elements that are energized. And if they haven't been energized in a while, its burning off some debris.
Mar 07, 2017 | Bryant Heating & Cooling
We have a carriers air con that is about 4 yrs old it has a remote control and digital readings on the unit it is in the wall we can not get it to heat but it does cool we didnt put this in it was here...
Normally all air-cons carry an identifying label on the compressor unit. It has to by law state the gas used. On a split system this would normally be on the outside unit. Sometimes an additional label will be on one of the ends of the inside unit. Some units only do cooling - you need to check once you've found information. Check your remote control 'Mode' setting is correct - it should show a small 'sun' to indicate heating. A small 'icicle' looks similar, but means cooling. Then check temp setting is high enough to cause heating.
Jun 12, 2011 | Carrier Heating & Cooling
I am trying to replace my old bryant heat pump with a new bryant heat pump, but I am having a difficult time figuring out the tonage. Can you tell me if I have the model number?
yes just post the model number and someone will be glad to help you..
fyi if the model number has for example 373036 373042 373048
the o and number after it usually is the btu value...
12000 btu's = 1 ton so a 036 would be a 3 ton 042 3 1/2 060 would be a 5 ton
post the number someone will help you out... another way to find out
carrier which makes bryant units can help you also
a number for ft. worth location is 817-834-4496 good luck to you
Feb 10, 2011 | Heating & Cooling
Wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
May 27, 2010 | Carrier 38CKC036 Air Conditioner
Run(heat) for a certain minutes then it stop.
You may have a durty evaporator coil do to a durty filter, the heat is cuting off by the limit control sensor
Feb 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Air not going cold its staying hot
Set the thermostat to COOl and lower the temperature control.
Jan 13, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
