The chain saw is a Homelite 330 and has never given me any trouble since purchased after hurrican hugo in 1989.
SOURCE: homelite runs wide open all the time
hi shoefam
check the cable to the trottle of the carb and the gasket.Disassembly the carb and check it.
savumihai71
SOURCE: Carburator adjustment for Homelite xl 12 chain saw
Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should get the engine running if it will. If it does not, check the lower diaphragm on the carburetor for hardness or cracking. You appear to be running on prime only--the carburetor doesn't seem to be pumping in fresh fuel. You may need to do a carburetor clean and re-kit. Check the fuel line condition and the fuel filter in the tank for plugging. Make sure the muffler and air cleaner are not plugged. Once you get the engine to continue running, warm the engine up. Open the throttle and adjust the H needle CW--the engine should start to speed up, but still 4-stroking. The proper setting is 4-stroking, but immediately 2-stroke when cutting. Release the throttle and adjust L needle CW so that the engine runs fairly smoothly, yet will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Testimonial: "Thanks for the help. A very complete answer should cover all the possibilities."
SOURCE: why will homelite 290 chainsaw not start?
Make sure you have blue, snappy spark at the plug (set at 0.020"). If ok, put some fuel mix in the plug hole and try to start--it should pop several times. If pops, then check the fuel system. Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors for theory and troubleshooting. Be sure to check the placement of the gasket in the lower chamber. Hope this helps!
SOURCE: I have a Homelite model 20 chain saw. It will
on your machine may be on the side of it that led into the carb should have H for high L low L is for the idle H is for all out ball to the wall you will need a small long screw flat head . put in the H ,turn out for more gas in for less good luck
SOURCE: homelite 240 chain saw will start & run for about 2 min then when
Delete this; no response to clarification since Feb.
