Reference my problem and your answer Ref 2100series printer -
I cannot locate the printer driver supplied with the machine, can you e-mail me another?
Best regards, James Goodman.
  • 36 Answers
Hello there
if you goto the web site www.hp.com they have all drivers for all of their printers and the different os's that are supported.
start at the support & drivers tab, and go from there.
there is no charge as long as you dont request a cd to be shipped to you.
norm
Posted on Nov 06, 2008
What would cause only 2.5 volts being supplied to TPS at the reference wire? What would cause oil light to come on and car going into limp-in mode after OBDll scanner was used.
The PCM supply's the five volt reference . Is there five volts at the PCM on that gray wire , T - pin that wire at the PCM connector . If no 5 volt ref. there PCM is bad ! Provided one of the other sensors on the 5 volt ref. circuit isn't pulling it down ! Check pin's 4 & 5 in the DLC connector ,these are ground circuits . One is sensor ground an other is body ground . Your vehicle has two 5 five ref. circuits A & B . What type scan tool did you use ? Your 5 volt ref. circuit inside the engine computer is shorted because of your code reader .
Jan 08, 2016 | 1997 Buick Park Avenue
I can not connect my printer to my PS optus wifi
I am sorry but you will need to provide more information in order to get help with your problem.
What actual printer model do you have?
Is this a networked printer with a wireless adapter fitted?
Do you have a wireless router or access point?
You mention a PS Optus - I assume this is a PlayStation device - how are you connecting the printer to this box?
I found a reference to the A3-3311 error in a Samsung CLX-318X document which states that this is a failed connection to a SMTP server which doesn't make a lot of sense. SMTP = Simple Mail Transfer Protocol and is used for e-mail when sending an outgoing message. Printers do not normally send e-mail messages in my experience.
Dec 30, 2011 | Samsung Office Equipment & Supplies
The printer turns on but afterwards it displays 1, P, 0, 7. then it repeat displaying P07. What does it mean? Please help me. Thank you. God bless.
If my answer helps you, please give me a 4-thumbs up rating.
This error indicates a service problem with the printer. Sometimes recycling will fix, or the paper path may be jammed.
Here is an excerpt from the manual for this error code:
Turn off the machine, and unplug the power cord of the machine from the power supply.Plug the machine back in and turn the machine back on.If the problem is not resolved, contact the service center. Print this out and you can have a list of the error codes for reference. http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp250#ServiceAndSupport
Aug 04, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
The all in one centre will not start up and keeps looking for scanning applications. I have downloaded the latest drivers and it makes no difference. I am running XP pro and never had this problem until I...
Hi, apologies - i am unable to answer your question ref; printer problems. BUT i note, previously you were able to advise someone else with regard to problems with a cable & wireless CWD4900SE answer machine. I have contacted C & W, who say they no longer supply any telecoms eqpt, and that they originally only supplied through Alba, in the UK. If you still have the user manual, could you please let me know. My email address is sphowell11@gmail.com Many thanks. Steve - Hull
Mar 06, 2011 | Lexmark Office Equipment & Supplies
Car wont start after sitting for 6 hours runs like new if you start it before 6 hours codes p1496 always there when it fails to start.
Yes the car will fail to start due to this error code p1496.Its possible. Description of code P1496 is 5 Volt Supply Output Too Low. But to locate the exact fault you will need to do some troubleshooting. The 5 V ref. can be low for a couple reasons. 5V is supplied to several engine sensors, like the crank, cam, Map, etc. It's not uncommon on chryslers for one of the sensors to short the 5 V. reference voltage and get that code. To check if a sensor is bad and shorting the ref. just check for voltage on the 5V ref as you unplug each sensor. If the 5 V. ref. returns, the last sensor you unplugged is the shorted sensor. It's usually the crankshaft sensor, but not always. If the 5 V. ref. still is shorted after unplugging all sensors that receive 5V. ref, check for 5 V. at the PCM. If it's present at the PCM, there's an open or short after the PCM. If there isn't 5V ref at the PCM, it's probably a bad PCM. That is a 5 volt supply too low. You will want to check the connections at the MAP and TPS sensors. --------
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Sep 22, 2010 | 1999 Chrysler Concorde
HOW I CAN DOWNLOAD ENGLISH LANGUAGE DRIVER FOR ALPS MD-5500 OR FROM THRU WHAT SITE I CAN ORDER IT ??
Simple answer - you can not.
If you want the English driver for this machine, you have to purchase a printer from Alps Supplies. You will then be provided with an English driver.
If you did not buy the machine from Alps Supplies, you have no chance of getting the English driver.
Jun 15, 2009 | Office Equipment & Supplies
I need Vista driver for my MF JET 495
I will give you a easiest way for finding the drivers that you need for your hardware.Just download the software named driver magician.Install it and it will search for the drivers that is not installed for the hardware you have through internet and will download it for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
May 18, 2009 | Philips MF-Jet 495 Multifunctional Machine...
Don't know how to connect
Hi, I'd love to help you with the problem you described.
  1. Connect your phone line (out of the wall or your phone modem supplied by your phone or cable company) into the jack on your MFC-240 has a picture that is shaped like a little telephone. These jacks are located on the lower left back corner when you are facing your printer.
  2. In the same location, there is another jack right next to the one you just plugged into. Take the phone cord that came with your printer and plug one end into the jack.
  3. Plug the other end of this cord into the base of your phone or answering machine.
  4. Test your connections by picking up your phone handset and listening for a dial tone.
  5. Next, set the receive mode your printer for fax only (if you set the receive mode to phone/fax or other mode, you could experience problems with your voice mail). Fax only will ensure that your printer will only answer fax calls. Here's how you do it.
Here's how:
  • Press the menu key on your MFC-240
  • Press 0 (display switches to initial set up)
  • Press 1 (display switches to receive mode)
  • Fax only should be the first item that shows on the display.
  • Press the ok button on your MFC-240. The machine is now ready to receive faxes.
If you have not done so already set up either your answering machine or your cable company voice mail.
If you found my answer to be helpful, please use our rating system to indicate your level of satifaction with my answer. Thanks for using FixYa!
Jan 28, 2009 | Brother Multi-Function Center MFC-240C...
In printing ledger tally 7.2 not show reference no.
i am unable to get printing in tally 7.2 please let me know how to get it
Nov 07, 2008 | Computers & Internet
Have got a printer HP Destjet F 2100series F4100series cannot get the disk to work it is a new one the book tells me to click my computer double-click the cd-rom icon but i cannot find this can you help...
Left click "START" button
Left click "My Computer"
Double left click the CDROM icon (Picture of a CD)
This will open your CDROM disk, look for setup.exe and double left click it.
If you can't find a setup.exe, look for the autorun file double left click it and in that file should be the startup file and location.
May 09, 2008 | Office Equipment & Supplies
56 people viewed this question
k24674
jasbo
jasbo
