Question about Canon imageRUNNER 210S Copier
Canon IR 210S "Close the Lower Right Door" warning
My Canon IR 210S keeps displaying the "Close the Lower Right Door" message. I open and close but the display doesn't go away and it won't allow me to copy. Is there a sensor or switch that has broken? or a reset?
Thanks in advance for your advice!
  • davisx6 Nov 11, 2008
    Thanks for your comment. Just so I know which door I am referring too. It was my understanding that the bottom door the message was referring to was the door that opens where you can clear paper.
    It seems you are referring to the Trays (drawers) that hold the various sizes of paper. There is no door on the front of this copier. There are several on the right side of the unit.
    I will investigate further but would appreciate any further clarification.
    Thanks!
  • Anonymous Mar 22, 2014
    the device is clean inside coz i had used the blower to ensure its so.
  • Canon Expert
  • 1,326 Answers
Yes there is a sensor that most likely got knocked out of place. What you can do is to turn the copier off and disconnect the bottom 2 trays from the main body of the copier and turn it back on and just use the top 2 trays. You can change the trays lay out to what ever size you want, but make sure you change the BLUE DIAL to the correct size you want to use. I belive the sensor is toward the front of the copier right by the edge of the door, it may be knocked out of place or the flag on the door is broken off or one of the door pins are broken and the door is not closing correctly.... Good Luck..
Posted on Nov 07, 2008
Canon ir 2016 toner bag full
I'm assuming it is the waste toner full message. Power down copier- Main Power. Open front door and gray handle to open left side door and pull out drum. On the top there should be an opaque disk to be removed and then you can dump the waste toner into the trash. BE VERY CAREFUL THIS COULD GET MESSY.! Slide the drum back back into position, close the left door and front door. Power up the copier and all should be good.
Mar 13, 2017 | Canon iR 2016i Black and White Copier
I have ir 400 machine its front door is close but error is close the front door whats problem
Either you misunderstand this message or the switch which says the door is closed is not doing so.
Nov 15, 2013 | Canon imageRUNNER 400S Copier
Hi i have canon ir 2018 machine with duplex but it dosent giving back to back print
Dupex is an optional item for this unit, fixed on right door and 1 wire harness to be attached with main unit which usually forget please check.
Jan 12, 2013 | Canon imageRUNNER 210S Copier
How do I change the drum in my Canon imageRUNNER 210S?
Open front door>turn down green handle>remove thumb screw on grey cover>slide out drum unit>unpack new drum>slide back into area where old drum was removed>reinsert thumb screw>lift green handle>close door.
Aug 11, 2010 | Canon imageRUNNER 210S Copier
Newly donated copier has message Close copier front door I do It does't work
try to see where the door has "nose" and where does it fits in! Its simple error where you need to straight up the "sensor" arm
Jan 08, 2010 | Canon imageRUNNER 210S Copier
CANON IR-1210 IN THE DISPLAY IS STANDING: CONTR. TONER/DRUM HOW CAN I FIXED THAT? JOHAN THE NETHERLANDS
try to open the front door were you put the toner and close.if still showing the message replace he drum.
Oct 21, 2009 | Canon imageRUNNER 1210 Copier
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
Canon GP335 - error E001
E001 is a no heat error.Open and close the front door.If that does not work you will probably have to call a copier technician.Good Luck
Mar 27, 2009 | Canon imageRUNNER 210S Copier
Canon IR210s copier
Are you sure you have the right toner??? It says it is for the IR-200-210 or dose it say IR-330 & IR- 400? If you look on the inside front door cover there are pictures showing how to install the toner, also there are pictures on the box the toner came in and also the display sceen will walk you through on how to replace the toner.. It slips in only one way and push down on it till it locks in then pull the blue tab till it displays "STOP" then push it back in and the push on the black part on the front of the developer unit to release the toner bottle and close the copier back up and lok the blue lever to the left and you are done. Good Luck
Jul 09, 2008 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 210S Copier Logo
192 people viewed this question
old marine
old marine
