The computer won't power up past 2-3seconds. To get it to power up at all you have to first disconect the power from the power supplie or pull out the power for the motherboard for 10 seconds and put it back in before the power swich will do anything. then when you turn on the computer it only goes on for about 2-3seconds (fans run on cpu case and power supplie fan turn on power light on front and no other lights come on also monitor turned on and blank)and then shuts off. has two "256mb DDR-400mhz-CL3 pc3200U-30330" memory sticks and a "Micro ATX W/350 W P/S" and "sempron 2500+ Socket A" cpu and i also cleared the cmos by pulling out the cmos battery and putting it back in.
-   I have a similar problem. I used the computer the night before (everything was fine) logged off. The next morning went to turn it on and it seems to want to start up okay. Lights are flashing and fans a going, but the screen stays black......no curser no nothing. I tried changing the video card and I still have the same problem. I rejacked the boards and pulled the batery on the Mb and still nothing. Also changed out the monitor that was the first thing. NOTHING. I am going mental!!!! Should I change the MB????? -   Raiderbravo
May 02, 2008
-   MY MOTHERBOARD NUMBER IS INTEL D845EPI/D8845GV5R. MY PROBLEM IS THAT WHEN I SHUT DOWN MY COMPUTER AND THEN START AGAIN IN JUST 30 SECONDS WHEN I START MY COMPUTER POWER SWITCH AGAIN THEN A BEEP SOUND COMES ON AND BLACK SCREEN SHOWS THAT YOUR CPU HAS HEATED AND PRESS F4 . -   pras_mish
Check that the CPU fan you are using has three wires going to the connector. This mobo will NOT startup unless it has the third tachometer pin. It does this to make sure the fan is always running to protect the CPU
Look for a ground fault.I replaced my Motherboard and the power stayed on long enough for the fan to turn about 1 sec. So I pulled all the power connections off and started with just the power supply,it stayed on , so the motherboard without the memory, cd, ect. I found the problem to be the motherboard was groundingout (a mounting screw was pulling it down to the case) I burned out my memory stick.
Had the same problem on my system. Still have. My problem was that the capacitators on the mobo are a bad quality. My supplier says every mobo dating from 4-5 years back will experience the same problem sooner or later. only Asus does not.
First symptoms are mysteriuous crashes of the system.
You can check your capacitators. They should have a flat top. If not, they have brursted open and they'll fail.
My workaround: try again and again. Only connect 1 HDD and 1 CD creates a larger change to succes. I myslef suspect it could also be a problem with the power supply not being able to deliver enough (stabel) power.
we had a similar problem with a compaq (pavillion?) it would get to a black screen but it would beep constantly we pulled the original ram out (we had extra) and it booted up fine the ram that didnt work was Hynix 256mb DDR-400mhz-CL3 pc3200U-30330
no audio driver. when i open my music there is a error found. said- bad directsound driver: bla bla...
(More)
no audio driver. when i open my music there is a error found. said- bad directsound driver: bla bla bla.. error code: 88780078
Just bought a 2002 Celica GT with a Venom 400 already installed. The car is really lethargic in...
(More)
Just bought a 2002 Celica GT with a Venom 400 already installed. The car is really lethargic in pickup with the 400 switch on or off. I currently have the car at an automotive repair shop and they are not familiar with the 400 system at all. The car has been serviced and tuned up and checks out O.K.otherwise, but still is noticeably slower on acceleration time than it should be. I am thinking it best to remove the Venum 400 system completely, but will this then cause a problem with the car's computer / programing? The car repair shop is not sure on this and therfore heistant to remove it. Your advice / assistance on this is appreciated. If I decide to try to keep the Venum 400, how best do I locate a company that is familiar service / operation wise for the product?.
