Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Ice Maker does not open rubber flap in door to let ice out........
Any help would be appreciated. The icemaker works fine and always has but just recently when you push in on the plastic dispenser to get regular cubes or crushed ice the ice drops into the area inside the door and then stops and the rubber piece won't open up to let the ice drop into the glass. We have to be careful or ice will spill over the top of the hopper in the door when we open up the door to manually push down on the black rubber piece and the ice drops fine into the glass and any others hits the floor. I know something must push the black rubber piece open to let the ice drop into the glass but I can't figure out what it is....... wierd but its a problem! I have a GE side by side. The rubber flap door does not open to let the ice drop down into your glass.
    Master:
  • 505 Answers
    Genius:
  • 1,239 Answers
Hi When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
To replace a gasket:
Step 1: Buy a gasket made specifically for the model refrigerator you own. So-called fit-all gaskets may fit after a fashion, but tailoring them to the door's configuration can be a tough job. If you aren't sure about the model number of your refrigerator, cut out a small section of the gasket and take the sample to an appliance dealer for matching. If the gasket has to be ordered, you can glue the section back into the gap with rubber cement for a make-do repair until the new gasket comes in.
Step 2: Let the new gasket sit about 24 hours in the room with the refrigerator to bring it to the correct temperature and humidity, or soak the gasket in warm water to make it pliable.
Step 3: Begin removing the old gasket. Door gaskets are held by screws, clips, or adhesives, and the gasket may have a retaining strip, which helps shape it and provides a fastening tab or guide. On some units, the gasket may be held in place by the edge of the door panel; the panel is fastened with spring-steel pressure clips, bolts, or screws. To remove the gasket, remove the fasteners that hold it and remove any retaining strips; or remove the fasteners that hold the door panel.
Step 4: Finish removing the fasteners on one side of the door at a time. Do not remove the entire door panel. If the gasket is held by spring clips, be careful not to pry too ******* the clips; they're under tension and could spring out of their mountings. If the gasket is held by adhesive, pry it off with a putty knife.
Step 5: When the old gasket is off, clean the mounting area thoroughly with mild household detergent and water. Remove stubborn adhesive with mineral spirits and fine steel wool, followed by a detergent/water rinse.
Step 6: Start the replacement at one side of the top of the door. Work down the sides to replace the entire gasket. Smooth the gasket evenly into place, easing it around corners. Use gasket cement to secure it if the manufacturer specifies this step. Make sure the gasket lies flat, with no lumps or curled edges.
Step 7: Replace the fasteners, retaining strips, or panel that held the old gasket. After the gasket is in place, tighten or loosen the mounting bolts necessary to adjust the gasket to the door jamb. If the gasket is glued in place, there isn't much you can do but wait for the gasket to conform to the door jamb.
Test the gasket on a freezer door with the same dollar-bill procedure; if the gasket is faulty, replace it with a new gasket made especially for the freezer. Do not remove the freezer door to replace the gasket. Freezer doors are often tensioned with spring devices, which can be very troublesome to replace after the door has been removed, and on some models wiring has to be disassembled as well.
Posted on Nov 06, 2008
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Jan 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
I have a KitchenAid side by side and my icemaker is not working
Check the black 2" fill hose going from the top of the freezer to the ice maker fill cup , to see if it's frozen up . Also check the optics system for proper operation . Open the freezer door and the laser should flash 2 times , pause , flash2 times , pause etc. Close the flap on the left side and the laser should go off . If the laser does not come on when the door is opened , then the ice maker is in the harvest ( dump ) mode . If it stays this way , then ice maker is bad .
Sep 12, 2009 | KitchenAid KSRG25FK Side by Side...
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Jan 06, 2008 | Refrigerators
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Oct 02, 2007 | GE 17.2 cu. ft. Top Freezer Refrigerator...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
176 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
