Question about Uniden Cordless Phone
Panasonic cordless handsets all say line in use
All my handsets say Line in Use even though nobody is on the phone, no fax is coming through and no phones are off the hook.
Have Panasonic KX-TGA541S and Panasonic KX-TGA560M and have never had this problem before.
  • 7 more comments
  • fionaw Nov 14, 2008
    Both my Panasonic cordless phone hand sets say 'line in use', there is no ring tone and I can't call out. What is going on?
  • Anonymous Nov 25, 2008
    my handset says line in use
  • Anonymous Dec 12, 2008
    This just happened to my cordless Panasonic phones too, is there anything that you can do?
  • khrussell Dec 13, 2008
    all phonbes say line in use
  • Anonymous Dec 18, 2008
    same problem as above" line in use" on, can't call in or out with kx tg 1034 I plug in my old phone and it works fine. The panasonic is brand new.
  • lateforthesk Mar 03, 2009
    I'm having the same problem with my Panasonic phone. I was at this site and went to take the batteries out and try the solution, and the phone was working . It's been saying "line in use" all day. Now the phone has a strange buzz on it, but it's working.
    It doesn't seem like it could be the "memory stuck" thing because it comes and goes? Oh my.
  • tlc9 Mar 18, 2009
    I had the same thing happen this morning - no phones off hook. I will try the solution listed here. I hope it works. Panasonic cordless.
  • piegirltoo Apr 29, 2009
    Same problem here. The offered solution didn't work for me.
  • Anonymous May 02, 2009
    My phone hasent rang all day and i thought that was really wired because i have my own buisness and it is always ringing and when i looked at my phone it said line in use i took all the batteries out and unplugged the phone jack and everything and even tried my land line phone and nothing please help me!!
I had the same problem. Something makes the phone's memory get "stuck."  Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
Posted on Jan 12, 2009
Better late than never. I had the same problem with Panasonic phone and Nettalk service. The problem with the "INUSE" was fixed by removing the phone line connection to my DirectTV DVRs. Once I did that, the phone immediately was ready for use.
Posted on Mar 10, 2011
Return to the manufacturer for replacement. I've spent hours on this and have had my line tested. It's a base station fault.
Posted on Oct 02, 2010
I had this problem as well. Take the battery out of the phone for a minute or two and then put it back in. Unplug the the phone (jack and power supply) including all extensions, then plug them in again. This should work. I worked for me.
Posted on Aug 27, 2009
  • Randy Atlas
    Randy Atlas Feb 22, 2012
    We were having this problem at work. I tried this suggestion and it did seem to work. But then the same problem came back the next day. Not sure what to do next. Maybe replace the batteries? (although the extensions have been working fine until this problem, and they have not lost battery power as far as I can tell)
This has happen to me twice. The first time a dog had chewed the extension lead for the base phone. Replaced the lead and it worked.The second time I thought it was the same problem with the lead that went through a door and the door had damaged the lead, so replaced the lead, but it didn't fix it. Got another phone and tested the upstairs jacks and there was no dial tone so called Telecom to fix. The weird thing was I still had internet and email access so I didn't think it was a problem at their end. Seems there was a fault at the exchange and our phones are all working again now.
Posted on Aug 07, 2010
SIMPLE FIX clears "In Use" from your Panasonic handsets: On the back side of your MAIN BASE SET ONLY, DISCONNECT both the phone & power lines and RECONNECT.
(This cleared my Panasonic KX-TX5100 base & KX-TGA510M handsets after a thunder storm.)
Posted on Mar 01, 2017
4 Suggested Answers
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Posted on Jul 06, 2008
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Posted on Feb 05, 2011
  • 4955 Answers
SOURCE: Error message CHECK TEL LINE
This sort of issue requires you to check if the base or the phone line has a problem.
I prefer to use an old corded phone for testing. I also get a new RJ-11 cable. Unplug your phone base from the jack and check for dial tone when you plug in your test phone.
If you get a dial tone on the test phone, try the new cable with your cordless phone. If you still get that message, then the phone has failed. If it is under warranty, contact the manufacturer for repairs. If it is out of warranty, then determine if it is worth fixing or replacing. These phones are not designed to be fixed by the end user.
If you do not have a dial tone, take your test phone to another jack on the phone line. Check if there is a dial tone at that point. If there is a dial tone, the problem is at the first jack or the phone line to the jack.
If you still do not have a dial tone at the second jack, find where your telephone service comes in. Open the box and determine the type of connection used. If you are lucky, it will have RJ-11 connections. Plug your test phone into the jack and check for a dial tone. If you do not have a dial tone at this point, call your telephone company. They will fix the problem for free. If you find that the connection is not an RJ-11 type, call the phone company and have them test the line and repair it if needed.
If you have a dial tone at the service box, then you have an inside wiring problem. Inspect the visible wires for damage. Open the faceplates for the jacks and check for loose wires. There are two types of connectors. Screw type connectors need the wire stripped back a little then wrap around the screw and tighten. The other type is a punchdown jack. To repair a loose wire in this, you will need a punchdown tool. These are often available in hardware/home improvement stores in the wiring section. http://www.lanshack.com/wire_phone_jack.aspx has clear pictures of the wire color to pin pattern.
You may want a professional to check the wires inside the walls. Your telephone provider will do this for a fee.
I hope this helps.
(who has had outside phone line problems due to rodents chewing on wires, road crews digging just a little too much, and lightning damaging a DSL filter.)
Posted on Jul 08, 2011
Manual for Panasonic kx-tg6521R cordless with answering machine 2 handsets
It is this one. The handsets are the same on the base unit and the extensions.
KX TG6521 Cordless Panasonic
Jul 09, 2016 | Panasonic Lands Phones
How do I change number of rings to accommodate fax on same line?
Go to initial settings and then scroll up or down to "set tel line" then scroll to "set line mode". That will take you to either line A or line B.
Aug 24, 2014 | Panasonic Dect 6.0 4 Handset Cordless...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
I have a Uniden cordless phone #D2CT 6.0--I love the phone but the party on the other end of the line can barely hear me -how can I fix this or this a bad phone???
At 20 ft line of sight, you should have perfect reception with most any cordless phone.
The fuzzy signal can indicate:
1.
A weak signal between base and handset.
20 ft line of sight should have a good strong signal.
Your handset may be defective.
Or, your handset battery may be weak.
Your base unit may be defective.
2.
You may be experiencing RFI Interference.
Is the base unit next to any other electronic devices?
If it is next to a wireless router or some other wireless device, it may be overloaded by the nearby signal (even if on a different frequency)
I've got a 5 year old Panasonic 5.8 Ghz cordless phone connected to my VoIP box. I just tested it from about 25 ft away from the base unit in another room with a wall in between and my reception is perfect.
I did the same test with my Panasonic DECT 6.0 phones (1.9 GHz). The first handset is slightly fuzzy, but otherwise good signal. The 2nd handset was perfectly quiet with good strong signal. So, there is a difference between two identical handsets connected to the same base unit. This indicates to me that one handset is better tuned than the other. Nothing I can do about that but get a new 2nd extension cordless handset. Sometimes, it's just luck of the draw
Feb 15, 2011 | Uniden DECT 6.0 Cordless Phone ID
I just want to make sure that I am shopping for the right product. We have a dental office with 1 phone#, but we have a rollover line. Our fax has it's own# which "was" what we called line 3 but as of...
Yes, you can use a regular 2 line cordless phone with your 4 line corded systems. The only concern is when you put someone on hold. The on hold function may not release if you have different makes of phone. If you already have Panasonic get a Panasonic 2 line cordless phone with the on hold feature.
Yes, you can just take line 3 and plug it into your new fax. I might suggest looking into a fax to email service instead of buying a new fax. If you receive more than send it's a great way to save on the phone line and paper.
Digital phones are pretty secure, no one will accidentally hear your conversations. It is not encrypted but I think it would be perfectly fine in your office.
Greg
Feb 18, 2010 | RCA 25205RE1 Phone
Both my handsets say Line in Use even though nobody is on the phone, no fax is coming through and no phones are off the hook.
Sounds like your telephone line is dead. Call your service provider to determine if its a problem on their end.
Dec 16, 2009 | Uniden Cordless Phone
Error message -using handset (no handset on the machine. mfd - 1515
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Nov 17, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Panasonic phone system, won't release the phone line
You might try removing the battery pack and see if that resets the phone. If not, you probably have a component inside the phone that has failed.
On most cordless phones, it is not cost effective to have them repaired.
Oct 16, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
Not able to phone out from extension phone
Try plugging the phone in the handset jack of the fax
Aug 11, 2007 | Philips IPF-174 Plain Paper Inkjet Fax
Uniden Cordless Phone Logo
25,320 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
